pax Profi-Schrauber
2000 Volkswagen Passat Support
20-05-2012, 21:54 Subject: Troubleshooting manual air conditioning system, Volkswagen Lupo 3L |
Unfortunately, the air conditioning system doesn't work on my new toy. As far as I can tell, it's not diagnosable. The following steps have been taken so far:
* Refilling (vacuum test performed; approximately half of the refrigerant was missing - I suspect the vehicle has never had its air conditioning system serviced).
* Visual inspection - magnetic coupling appears not to engage.
* Air conditioning fuse checked (was OK).
* G346 Temperature sensor for compressor shutdown checked (approximately 1.03 kOhms at 15°C, approximately 2.3 kOhms after a few minutes in the freezer, approximately 0.33 kOhms after a few minutes in the oven) - I don't have the characteristic curve, but it seems to be functioning generally.
Resistance measurement of the climate compressor's magnetic coil: approximately 4 ohms (likely the input/output?).
* Voltage measured at the disconnected connector of the magnetic coil - consistently around 9.2V, regardless of whether the air conditioning is on or off.
* Checked the cable to the fan control unit (which also connects to the magnetic coupling) - it's okay.
* Pressure sensor G65 was temporarily replaced with a used one â no change in the situation.
I'm starting to run out of ideas. What else can be done that would be meaningful?
Bye.
peace
Translated on 12-07-2026, 18:26.
Profile PM Garage |
guste100 Profi-Schrauber
Joined: 07/27/2004 Posts: 2403 Karma: +441 / -0 Location: Mitte Schleswig Holsteins 2007 Volkswagen Passat Premium Support
21-05-2012, 13:55 Subject: Subject: Troubleshooting manual air conditioning system, VW Lupo 3L |
Hi Pax,
If the connector is disconnected, you won't be able to measure voltage at the magnetic coupling because the control unit detects this and shuts it off.
Since you've already checked the fill level: Just to test it, have you tried applying 12V directly to the magnetic coupling?
It's not uncommon for the compressor to become blocked due to a lack of refrigerant, and after that, the rubber pads on the magnetic coupling are usually damaged. However, you can only determine this after performing a 12V test.
If the magnetic coupling functions correctly after the test, then only the fan control unit in the engine compartment on the driver's side and its input signals remain as potential causes.
A) You've already measured the temperature sensor. I can't comment on the values themselves, but they seem plausible. Does this value also appear between pin 14 and 5  4 of the fan control unit (to rule out a broken wire)?
B) Connects to pin 14/8 and receives +12V (turns on the interior fan).
C) What signal is received at pin 14/3 from the engine control unit (ECU)?
D) Is pin 14/9 the ignition positive terminal?
E) 14/10 = Connection to the magnetic coupling?
F) 14/6 = Is mass present?
G) 14/7 = Coolant thermostat switch.
H) Continuous power supply to circuits 4/1+3 and 14/3? (Fuse SA4, 7, and
I) What is the issue with pin 14/2 (signal from the high-pressure sensor)?
My personal order of tests:
1) 12V to magnetic coupling.
2) Point H, check the fuses.
3) Then the rest.
Greetings.
Sure.
Here is the translation of the text from German to English:
"Guste" means "gust" in English. It refers to a sudden and strong gust of wind.
Translated on 12-07-2026, 18:31.
Profile PM Garage |
Joined: 04/12/2002 Posts: 18115 Karma: +801 / -0 Location: St.Gallen 2018 Volkswagen T6
21-05-2012, 16:24 Subject: Troubleshooting manual air conditioning system, Volkswagen Lupo 3L |
Please upload the vehicle's Autoscan data and check the A/C deactivation conditions within the measurement blocks. Is it a Climatronic system or a manual one?
Translated on 12-07-2026, 18:34.
Profile PM WWW Garage |
pax Profi-Schrauber
21-05-2012, 23:55 Subject: Troubleshooting manual air conditioning system, Volkswagen Lupo 3L |
Thank you for the suggestions. Unfortunately, I only have time to work on the car during weekends, and the upcoming weekend is already booked. Therefore, the flow of information might be a bit slow.
@ guste100 :
I didn't dare to apply an external current to the magnetic coupling because it would have required me to fiddle with the small connector that had only two wires â I wasn't comfortable doing that.
It's certainly an important point to only take measurements with the A/C compressor engaged. But how do you practically achieve that? All the connectors are sealed.
I would now try to obtain some connector housings and build an adapter. However, this only works with the connector for the magnetic coupling. You can't get anywhere with the control unit using this method, or is there a simpler way (I actually don't want to cut any wires)?
Regarding point H, I have completed the following: In addition to checking the circuit breakers in the main electrical panel (SB26), I have also inspected the fuses in the engine compartment (both blade fuses and strip fuses).
Point I: Is that the G65? As far as I know, it generates a PWM signal. I haven't measured anything yet (and I haven't even checked the cable with a multimeter), but I have at least replaced the sensor with another one (used).
@Rainer:
It is a manual air conditioning system (see subject).
Autoscanning (not from the weekend, but the error was already present).
Code: |
Sonntag,01,April,2012,14:43:54:01334
VCDS Version: RKS 11.11.2
Datenstand: 20120130
Fahrzeugtyp: 6X - VW Lupo
Scan: 01 02 03 08 15 17 19 25 35 37 44 45 55 56
Fahrzeug-Ident.-Nr.: WVWZZZ6EZ3W000615 Kilometerstand: 256670km
Adresse 01: Motor Labeldatei: RKS\045-906-019-ANY.clb
Teilenummer: 045 906 019 AE
Bauteil: 1,2l R3 EDC 0001DS 1537
Codierung: 00002
Betriebsnr.: WSC 01233
VCID: 58B5E540B8084A3
WVWZZZ6EZ3W000615 VWZ1Z0B2123738
Readiness: 0 0 X X X
Adresse 02: Getriebe Labeldatei: RKS\6N0-927-735.lbl
Teilenummer: 6N0 927 735 H
Bauteil: DS085 Getriebe 1390
Codierung: 00000
Betriebsnr.: WSC 00000
VCID: 3D7B54D4376A8FB
Adresse 03: Bremsen Labeldatei: 6E0-907-379.clb
Teilenummer: 6E0 907 379 A
Bauteil: ABS 30 IE CAN V006
Codierung: 05623
VCID: 2F677E9CED066DB
Adresse 15: Airbag Labeldatei: RKS\6Q0-909-605-VW5.lbl
Teilenummer: 1C0 909 605 A
Bauteil: 2T AIRBAG VW51 0004
Codierung: 12884
VCID: 224187A8AED4D03
Adresse 17: Kombiinstrument Labeldatei: RKS\6X0-920-xxx-17.lbl
Teilenummer: 6E0 920 800 J
Bauteil: KOMBIINSTRUMENT BOO V10
Codierung: 00134
Betriebsnr.: WSC 45241
VCID: 28559580C8E83A3
Adresse 19: CAN-Gateway Labeldatei: RKS\6N0-909-901-19.lbl
Teilenummer: 6N0 909 901
Bauteil: Gateway K<->CAN
Codierung: 00006
VCID: F0E53DE0B0B8B23
Adresse 25: Wegfahrsperre Labeldatei: RKS\6X0-953-257.lbl
Teilenummer: 6X0 953 257
Bauteil: IMMO 0008
Codierung: 00001
VCID: FDFB14D4F7EACFB
I think I may have found the deactivation conditions while searching before, but I didn't note them down. I seem to remember something like 144 (ignition on, climate control on, engine off) or 0 (engine running, climate control on). I thought that at least sensor G65 might be diagnosable. However, there was something about guided troubleshooting, and I always get stuck with VCDS because I don't know what to do in those cases.
Bye.
peace
Translated on 12-07-2026, 18:37.
Profile PM Garage |
brezelmann01 Profi-Schrauber
Joined: 09/14/2002 Posts: 714 Karma: +75 / -0 Location: Niedersachsen
06-06-2012, 17:42 Subject: Troubleshooting manual air conditioning system, Volkswagen Lupo 3L |
Hello!
Does the 3L engine also have fuses for the radiator fan located in the engine compartment? If so, try removing them and checking for corrosion. This is a known issue with the 6N and 6X models.
Is the air conditioning fan running?
[VERKAUFT] Polo 6NF 1.4TDI (AMF) mit nachgerĂźstetem DPF, STH+FFB, Bj. 2000, 222tkm
Translated on 12-07-2026, 18:39.
pax Profi-Schrauber
06-06-2012, 21:32 Subject: Troubleshooting manual air conditioning system, Volkswagen Lupo 3L |
"@brezelmann01: Yes, I checked the fuse box in the engine compartment, including the fuses, and they are all fine, and there's no sign of corrosion. However, the fan is not turning on."
"I finally received the connectors and connector housings and have built the adapter, so I can now safely energize the magnetic coupling on the air conditioning compressor and also take measurements while it's connected. However, different types of connector housings were installed than what was specified in the documentation. I haven't actually started conducting the experiments yet."
Here's the question again for everyone: The homemade adapter for the magnetic coupling should work for now. I still need to figure out how to practically measure things, for example, at the control unit or the pressure sensor. Are there any measurement adapters available? Or do you have to notch the lines or remove the individual wire seals?
Bye.
peace
Translated on 12-07-2026, 18:41.
Profile PM Garage |
08-06-2012, 17:34 Subject: Troubleshooting manual air conditioning system, Volkswagen Lupo 3L |
Hello!
If the air conditioning fan isn't starting, you shouldn't immediately try to directly power the compressor! This usually means that either the temperature sensor at the air intake is faulty, the fan control unit (which also controls the compressor and everything else) is malfunctioning, or there might still be a problem with the fuses (still my favorite possibility). Turn on the AC and measure the voltage drops across the fuses near the battery.
P.S.: Is the measurement block for climate control on/off in the engine control unit being monitored? I mean, is the switch on the control panel actually working?
Translated on 12-07-2026, 18:43.
pax Profi-Schrauber
09-06-2012, 8:05 Subject: Troubleshooting manual air conditioning system, Volkswagen Lupo 3L |
@ brezelmann01 : Thank you for your input. I'm not sure if the fan starts automatically with the air conditioning when the Lupo 3L is turned on, because energy saving is a priority. It might only start at a certain coolant temperature - but that's just a guess.
The "frost sensor" is likely the G346 (temperature sensor for compressor shutdown) â I have at least already checked its functionality with a small series of measurements (see my first post, point four).
The fuses appear to be in good condition, both visually and electrically. I cannot detect any signs of scorching or corrosion that are sometimes present in this type of construction (see picture).
Let's see when I'll have time again to take measurements on the car. Then I'll try to address the remaining open issues.
Bye.
peace
| Description: |
| Sicherungshalter auf Batterie Lupo 3L" auf "Sicherungshalter Motorraum Lupo 3L" (Batterie ist nämlich im Kofferraum bei diesem Modelljahr) |
| File size: |
140.69 KB |
| Viewed: |
23326 times |
Translated on 12-07-2026, 18:45.
Profile PM Garage |
pax Profi-Schrauber
18-06-2012, 7:12 Subject: Troubleshooting manual air conditioning system, Volkswagen Lupo 3L |
Thank you for the help; the problem is temporarily resolved. The checklist from guste100 contributed significantly to this solution.
A positive wire leading to the fan control unit was so heavily oxidized under the insulation that none of the strands were sufficiently conductive. After being bent a few times, the cable completely broke.
For now, I've soldered a piece of wire in between to make the connection, as there was just enough cable left on the connector. Unfortunately, I haven't been able to remove the contact from the connector housing using my available unlocking tools. I tried using the timer contact release tools, but they seem unsuitable. How can I get the contact out, and with what tool?
Bye.
peace
| Description: |
| Stecker fßr Lßfter der Klimaanlage (Lupo 3L) auf "Stecker Lßftersteuergerät |
| File size: |
139.43 KB |
| Viewed: |
13864 times |
Translated on 12-07-2026, 18:47.
Profile PM Garage |
Autoservice Profi-Schrauber
Joined: 04/14/2012 Posts: 2130 Karma: +99 / -0 Location: Nähe Dßsseldorf
18-06-2012, 16:13 Subject: Troubleshooting manual air conditioning system, Volkswagen Lupo 3L |
Okay - and thank you for the feedback  .
*Nichts ist einfacher, als sich schwierig auszudrĂźcken......*
Translated on 12-07-2026, 18:48.
pax Profi-Schrauber
07-04-2013, 16:11 Subject: Troubleshooting manual air conditioning system, Volkswagen Lupo 3L |
"In the Lupo 3L, the radiator fan also starts immediately after turning on the air conditioning. In addition to the original problem mentioned in the thread, the first speed setting of the radiator fan was also defective in this vehicle."
Bye.
peace
Profile PM Garage |
08-04-2013, 9:55 Subject: Troubleshooting manual air conditioning system, Volkswagen Lupo 3L |
Thanks for the additional feedback after all this time. It's great to continue sharing knowledge in the forum.
Translated on 12-07-2026, 18:49.
Profile PM Garage |
