Exhaust pipe for auxiliary heater
Post24-03-2013, 22:03    Subject: Exhaust pipe for auxiliary heater Quote
Hi.
I currently have a 2010 Touran with a crack in the exhaust pipe of the auxiliary heater.
While the individual parts are labeled in the picture, they are not sold separately; they are only available as a complete exhaust system.
Does anyone know of alternative sources for 5 cm corrugated pipe?
 Abgasrohr Zuheizer
 File size:  112.29 KB
 Viewed:  13075 times
DieselBär30x
Avatar-DieselBär30x
Post24-03-2013, 23:07    Subject: Exhaust pipe for auxiliary heater Quote
Hi Martin!
You can find them at any Webasto/Eberspächer/StHzg. dealer.
If necessary, I also have some extra lying around, and I'd be happy to send you some.
Best regards from Munich!
Post24-03-2013, 23:17    Subject: Exhaust pipe for auxiliary heater Quote
...or with a reputable Bosch service center that offers adequate support.
*Nichts ist einfacher, als sich schwierig auszudrĂźcken......*
mdonau
1988 Audi 80
Post25-03-2013, 13:57    Subject: Exhaust pipe for auxiliary heater Quote
..and pay attention:
Webasto 22mm, Eberspächer 24mm.
Passat 3B AFN Syncro, E46 330D, T3 1,7TDI, T3-Syncro TD
Post27-03-2013, 18:55    Subject: Exhaust pipe for auxiliary heater Quote
Here comes the big one.
In the Golf (same heater as in the turkey), you can buy this part separately.
1K0 819 178 C
Okay, I'll get back to you later - I need to go take my measurements.
Post27-03-2013, 19:36    Subject: Exhaust pipe for auxiliary heater Quote
SHIT
Horn off.
Remove the bells.
and now it's not going any further - the pipe is really stuck on the two flanges.
And if I just wrap GUMGUM around it?
 File size:  246.13 KB
 Viewed:  9531 times
 File size:  295.79 KB
 Viewed:  7612 times
Post27-03-2013, 20:37    Subject: Exhaust pipe for auxiliary heater Quote
Spray with rust remover. If that doesn't work, cut the pipe and carefully break off the rest using pliers or a pipe cutter.
Steffen W
Karma: +104 / -0   Thank you, like it!
Post29-03-2013, 11:05    Subject: Exhaust pipe for auxiliary heater Quote
Definitely replace it, don't repair it.
I also have one. It's 24mm. If you're interested, let me know.
 File size:  32.74 KB
 Viewed:  6933 times
Passat Variant BGW 2005
Post30-03-2013, 16:47    Subject: Exhaust pipe for auxiliary heater Quote
The old hose crumbled in the middle.
I have wound down the ends.
With enough courage, everything went perfectly smoothly.
I had to scrub the bottom of the SH very thoroughly.
Unfortunately, I made the new arch slightly too wide (the old one was 20cm when measured, the new one was shortened to 21cm), so the horn had to be repositioned icon_smile.gif.
When does the old auxiliary heater actually turn on?
I would like to test the fun.
 File size:  70.94 KB
 Viewed:  21827 times
Steffen W
Post31-03-2013, 8:11    Subject: Exhaust pipe for auxiliary heater Quote
Eberspächer and Webasto both offer heat-resistant rubber sleeves that can be slipped over the exhaust pipe to keep it a safe distance from other parts, especially in tight spaces. Heat-resistant tape commonly used in motorsports is also excellent for insulating the exhaust pipes of auxiliary heaters. As a result, the exhaust pipe will be at best hand-warm, and the risk of fire is eliminated.
 File size:  29.22 KB
 Viewed:  7231 times
Post31-03-2013, 10:29    Subject: Exhaust pipe for auxiliary heater Quote
NE,
There's nothing wrong with the pipe.
I only measured it a bit too long, and I only realized after the complete assembly that the horn still needs to go in front.
Okay, I've adjusted the horn mounting bracket, all done.
If you compare my first and last picture, you can guess what I did by looking at the steps of the stand.
Removing the pipe bend again seemed like too much work, and I felt that it rusted through so quickly (MJ10) mainly because of its tight bend.
Steffen W
Post31-03-2013, 10:48    Subject: Exhaust pipe for auxiliary heater Quote
It's okay. I just meant it in a general sense, in case someone ever needs to install exhaust pipes like that. In the engine compartments of modern vehicles, which are often enclosed with plastic, the fire hazard posed by auxiliary heaters is a factor that should not be underestimated.
michiglaser
2007 Audi A4 Avant
Post08-05-2013, 14:37    Subject: Exhaust pipe for auxiliary heater Quote
In the SHK (sanitary, heating, and air conditioning) industry, there are flexible stainless steel corrugated tubes available for solar installations.
They might not be quite as flexible, but you can often find leftover materials at your local heating and plumbing supplier.
At least one part fit the Eberspächer auxiliary heater from the T4.
T5 California (CFCA) 4Motion
A4 B8 Avant (CDUC)
G4 (ASZ), T4 (AXG)
No new posts Install Parking Heater in VW Passat 3BG Troubleshooting & Guides
No new posts VW T4 AHY: Defective Auxiliary Heater / Parking Heater Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Standheizung Einbau: D5WSC mit Easystart R+ Installation Troubleshooting & Guides
No new posts Polo 6R - Exhaust pipe with throttle valve unit - where t... Diesel Engine Technology
No new posts Auxiliary Heater for V6 TDI Engine Diesel Engine Technology
No new posts Heated Seats Audi A6 2.5 TDI V6 Diesel Engine Technology
No new posts Standheizung??? Diesel Engine Technology
