T3Surfer Profi-Schrauber
Joined: 09/17/2004 Posts: 1833 Karma: +34 / -0 Location: Frankurt 2001 Seat Toledo Premium Support
05-09-2012, 22:15 Subject: Audi A4 B5 1.8L Gasoline Engine Air Conditioning (Solved) |
I have here an Audi A4 B5 from 1996 with a 1.8L gasoline engine; it should be an ADR model, but I'm not sure  . The air conditioning is not working, and the fans in the engine compartment are not turning on. On the automatic climate control, the snowflake icon doesn't activate (it only lights up briefly when the snowflake button is pressed).
Manually powered compressor ---> The magnetic clutch engages, and the air conditioning cools.
Refrigerant amount: Correct. It was only missing 130 grams, but that wasn't the problem; it has now been corrected. Fuses also located behind the steering column cover. I.O. (In Ordnung - meaning "OK" or "in good condition").
I'm looking for a wiring diagram for the air conditioning system to help with troubleshooting.
NA,Gehörlose wie ich können auch Schrauben! Ihr HÖRT ich FÜHLE! T3 TD EX-JX Jetzt 1Z mit 122PS und Renaultgetriebe Golf II TD Bj 84 512Tkm Passi 35I 1Z 468Tkm--> Seat Toledo AHF-- Toledo ARL 477Tkm mit Spritspartuning  99er T4 Syncro-Cross 100800km grad eingefahren
Translated on 05-07-2026, 11:28.
Profile PM Email Garage |
05-09-2012, 22:44 Subject: Audi A4 B5 1.8L Gasoline Engine Air Conditioning (Solved) |
What does the error memory say?
But if the snowflake disappears immediately, it usually means there's not enough refrigerant, or in your case, the control unit (STG) thinks there isn't, because the pressure sensor is probably defective.
Translated on 05-07-2026, 11:29.
Profile PM Garage |
05-09-2012, 22:59 Subject: Audi A4 B5 1.8L Gasoline Engine Air Conditioning (Solved) |
I'm not sure if it's the pressure switch, so a wiring diagram would be helpful. VCDS cannot compete with climate.
Translated on 05-07-2026, 11:30.
06-09-2012, 7:30 Subject: Audi A4 B5 1.8L Gasoline Engine Air Conditioning (Solved) |
T3Surfer wrote: | | VCDS can't handle this climate control system. | But it has to, because these parts are definitely readable.
Profile PM Garage |
DieselBär30x Profi-Schrauber
Joined: 01/17/2008 Posts: 3560 Karma: +101 / -0 Location: München & Passau
06-09-2012, 8:00 Subject: Audi A4 B5 1.8L Gasoline Engine Air Conditioning (Solved) |
Hey everyone!
No, the climate control system, at least in the A4 B5 with gasoline engines, is not designed to be easily diagnosed.
Is it also stated like that in the documentation  ?
Best regards from Munich!
EDIT: (I believe) until around model year 1996/1997.
Translated on 05-07-2026, 11:31.
06-09-2012, 9:31 Subject: Audi A4 B5 1.8L Gasoline Engine Air Conditioning (Solved) |
Okay, I need the wiring diagram for that, and I'll check it without using VCDS.
Translated on 05-07-2026, 11:32.
06-09-2012, 15:12 Subject: Audi A4 B5 1.8L Gasoline Engine Air Conditioning (Solved) |
It's been taken care of  .
06-09-2012, 15:43 Subject: Audi A4 B5 1.8L Gasoline Engine Air Conditioning (Solved) |
Could you also tell us what it was?
Profile PM Garage |
10-09-2012, 22:59 Subject: Audi A4 B5 1.8L Gasoline Engine Air Conditioning (Solved) |
"If I have the box back and I've successfully gotten it working, then yes!"
Currently, the climate isn't important; the car is running fine.
19-09-2012, 21:11 Subject: Audi A4 B5 1.8L Gasoline Engine Air Conditioning (Solved) |
Okay, so, the mechanic came to my place today for some other minor things, and he tried again with VCDS while the engine was running ---> and it worked!
I can't find the roof temperature sensor. Is it perhaps the sun sensor located in the center of the windshield, near the air vent?
What raises my suspicion is the value "-49.0°C" in field MWB 006, which refers to the "Fresh air blower."
and 007 1 position -48.0°C Headliner temperature
I suspect these are the reason why the compressor is being shut off; it's probably because something is causing the temperature to drop too low.
What are these things called in German? Okay, hier ist die Übersetzung:
"Unfortunately, my English is terrible."
Here:
Address 08: Climate Control/Heating. Label file: 4A0-820-043.lbl.
Control unit part number: 4A0 820 043 H.
Component and/or version: Climate control system, full automatic D05.
Encoding: 00060
Operating number: WSC 02315
VCID: 1E37896A9AACF49
3 errors found:
00786 - Roof temperature sensor (G86)
30-00 - Disconnection / Short circuit after positive terminal.
00800 - Blower temperature sensor (G109)
00603 - Actuator motor for footwell/defrost flap (V85)
41-00 - Blocked or Unpowered.
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Es ist ein wunderschöner Tag, um spazieren zu gehen oder ein Picknick im Park zu machen. Viele Menschen genießen das gute Wetter und verbringen Zeit im Freien."
Address 08: Error cleared.
Address 08: Climate/Heating (4A0 820 043 H)
20:35:28 Block 006: Outside air temperature.
19.0°C Outside air temperature.
22.0°C Fresh air intake duct.
19.0°C Temperature at the front bumper.
-49.0°C Fresh air blower.
20:35:28 Block 007: Interior temperature.
-48.0°C Headliner temperature.
28.0°C Instrument panel
59.0°C Engine coolant temperature.
58.0°C Engine coolant temperature.
20:35:28 Block 010: Compressor control.
0.0 Kickdown switch
0.0 Thermal switch
0.0 Compressor engagement
1.0 High-pressure switch
Translated on 05-07-2026, 11:36.
Autoservice Profi-Schrauber
Joined: 04/14/2012 Posts: 2130 Karma: +99 / -0 Location: Nähe Düsseldorf
19-09-2012, 23:23 Subject: Audi A4 B5 1.8L Gasoline Engine Air Conditioning (Solved) |
Try http://translate.google.de/ out.
Okay, I understand. Please provide the German text you want me to translate. I will only provide the English translation in the response.
Relatively satisfactory.
Translated on 05-07-2026, 11:40.
Rüdi Profi-Schrauber
Joined: 03/05/2005 Posts: 1511 Karma: +645 / -0 Location: Nord/Osthessen 2001 Audi A4 Avant Premium Support
20-09-2012, 11:19 Subject: Audi A4 B5 1.8L Gasoline Engine Air Conditioning (Solved) |
The only explanation I can think of for the sensor in the roof is that either the control unit doesn't fit the car or it hasn't been properly coded.
You can easily replace the fresh air sensor on the blower. Simply reach behind the blower housing from underneath and feel for the sensor and its connector. Disconnect the connector and then twist the sensor out using the bayonet mechanism.
If something is a bit fiddly, it will work, but the part number should be: 4A0 820 539.
"Mine was broken too, and the device started heating up excessively."
Translated on 05-07-2026, 11:41.
Profile PM Garage |
20-09-2012, 14:12 Subject: Audi A4 B5 1.8L Gasoline Engine Air Conditioning (Solved) |
Rüdi wrote: | I can only explain the entry with the sensor in the roof by saying that either the control unit doesn't fit the car or it's not properly coded.
It was also broken on mine, and then the box started heating up excessively. |
Car service: I tried using Translate, but it didn't produce anything useful.
Rüdi:
I tested this sensor, which is located behind the pollen filter, using a hairdryer, and it seems to be working correctly. The temperature reading for the "fresh air intake" increases appropriately, and the outside air temperature is also being measured correctly.
The heater is working normally despite some errors, but the air conditioning is not turning on.
I want to know what the two sensors displaying unrealistically low temperatures of -48 and -49 degrees are, and where they are located. My assumption is that these are the reasons why climate change is happening.
Translated on 05-07-2026, 11:43.
Joined: 04/12/2002 Posts: 18128 Karma: +803 / -0 Location: St.Gallen 2018 Volkswagen T6
20-09-2012, 15:10 Subject: Audi A4 B5 1.8L Gasoline Engine Air Conditioning (Solved) |
Quote: |
006,0, Temperatures (outdoor)
006.1, *calculated externally, for display*.
006.2, Intake manifold, (G89)
006,3, Bumper (G17)
006.4, Cold air outlet.
007.0, Temperatures (interior)
007,1,Roof (G86)
007,2,Distribution panel (G56)
007,3,calculated,coolant temperature.
007,4,Coolant temperature, (G110)
010.0, Stati
010,1,Kick-down,,0 = Kick-down switch open\n1 = Kick-down switch closed
010,2,Coolant temperature, too high, 0 = Temperature sensor open, 1 = Temperature sensor closed.
010,3,Output,Compressor Engagement (to Engine Control Unit)
0 = Output: Air conditioning compressor engagement open
1 = Output: Air conditioning compressor engagement closed
010,4,High-pressure switch, (F118), 0 = High-pressure switch closed\n1 = High-pressure switch open |
You have a private message.
Translated on 05-07-2026, 11:46.
Profile PM WWW Garage |
11-07-2013, 21:53 Subject: Audi A4 B5 1.8L Gasoline Engine Air Conditioning (Solved) |
The atmosphere of B5 is becoming tense again  .
I received a request to install a TÜV inspection and a different radio. During the radio removal, I noticed - see photo, that the previous owner had installed a C4 Climatic control unit in the B5.  The old coding was 0060 (probably some kind of V6 in the C4), and I re-coded it to 00140.  Eureka! The errors are gone, and the air conditioning is working.
Don't tell him when he picks up his B5, let's see if he notices.
Edit: Rüdi is absolutely right, how can one predict the future?
If it weren't for the radio, I would never have thought of it.
If the owner really wanted it to work back then, I could have simply manually reconfigured it using a separate switch, with low-pressure and high-pressure monitoring.
| Description: |
| File size: |
211.27 KB |
| Viewed: |
9279 times |
Translated on 05-07-2026, 11:49.
12-07-2013, 12:29 Subject: Audi A4 B5 1.8L Gasoline Engine Air Conditioning (Solved) |
The ways of the Lord are inscrutable... and thank you for the feedback  .
Translated on 05-07-2026, 11:50.
