Golf 5 Door Won't Open? Fix It Now!
Post18-08-2013, 19:25    Subject: Golf 5 Door Won't Open? Fix It Now! Quote
Hi.
I have no idea when or how it happened, but it's here now.
The bend.
Since the paint didn't show any damage, I suspect it came into contact with a tree trunk.
What's the best way to express this without making things even more complicated?
Okay, here's the translation:
Thank you.
 Tür Golf 5
 File size:  206.23 KB
 Viewed:  978 times
 Tür Golf 5
 File size:  150.23 KB
 Viewed:  827 times
Translated on 27-10-2026, 1:34.
Post18-08-2013, 21:10    Subject: Golf 5 Door Won't Open: Troubleshooting Quote
dieselmartin wrote:
How is the best way to express something like that, without creating even more wrinkles?
It's very difficult to describe it adequately with words; it requires feeling. icon_lol.gif
I had a similar experience with a silver Golf+ before, and I managed to fix it almost perfectly. You just need to know where and how much pressure to apply; some people have a knack for it, while others don't. However, I don't know if you have that ability.
Translated on 27-10-2026, 1:35.
Post18-08-2013, 21:15    Subject: Golf 5 Door Won't Open? Fix It Now! Quote
Reverse the icon_wink.gif door to the first notch - check if it's open enough at the bottom to slide a thin, flexible piece of wood behind it. If so, insert the wood diagonally behind the edge and carefully pull it outwards with both hands. You may need to gently push inwards at the point where the deformation starts or ends on the bottom edge. Is the adhesive strip (under the rubber) also deformed? That shouldn't be a problem either. However, you probably won't achieve 100% restoration.
Translated on 27-10-2026, 1:36.
Post20-08-2013, 18:09    Subject: Golf 5 Door Won't Open? Fix It Now! Quote
Okay,
How it must have happened is now relatively certain.
Door closed.
 File size:  100.34 KB
 Viewed:  788 times
Translated on 27-10-2026, 1:37.
Post20-08-2013, 23:46    Subject: Golf 5 Door Won't Open? Fix It Now! Quote
........and so, the search for the passenger who committed the crime begins. icon_confused.gif
Translated on 27-10-2026, 1:38.
Post21-08-2013, 7:27    Subject: Golf 5 Door Won't Open? Fix It Now! Quote
Therefore, I'm now simply going to focus on correcting it (I don't think I'll be able to fix it completely).
No new posts Golf 4 Fault Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf IV 1.9 TDI AXR - Stutters under load Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 5 1.4 BUD Misfire 2. Cylinder Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 3 Speedometer with Golf 4 6-speed? No signal. Diesel Engine Technology
No new posts Golf 2 GTD/16V: Brake Caliper & Wheel Bearing Mount Transmission, Chassis, Body & Interior
This topic is locked, you cannot edit or reply. Golf 3 TDI: Install 6-Speed Golf 4 Transmission Diesel Engine Technology
No new posts Is it possible to retrofit a VE-ESP system from a Golf 4 ... Diesel Engine Technology
