Octavia 2.0l TDI BKD Probleme (Gelöst) | Posts 48+
Go to page: Previous  1, 2, 3, 4
Post20-09-2013, 14:51    Subject: Quote
gtikasper wrote:
Here's a video; it's a bit old, but you can clearly see how the BKD engine shakes.
The rattling sound you are hearing is the brake pedal.
All data material relevant to the case should be uploaded in this section; see below for details.
Okay, I'm ready. Please provide the German text you want me to translate into English. Just paste it here, and I will give you the translation.
Translated on 11-08-2026, 0:23.
gtikasper
Post23-09-2013, 20:46    Subject: Quote
Sorry , ich kann leider kein anderes Dateiformat als mov. hochladen übers Iphone. The
Unfortunately, the .mov format is not supported in this forum.
Sure, here's the translation:
"Best regards."
Translated on 11-08-2026, 0:24.
Post23-09-2013, 22:54    Subject: Quote
Just use a converter (mov to avi).
pa-mm6
Karma: +1 / -1   Thank you, like it!
Post24-09-2013, 18:23    Subject: Quote
Hi, disassemble your high-pressure pump and rebuild it. I had the same problem with my BRD. After that, it worked perfectly again. You can also play it safe and have the pressure holding capacity of the tandem pump checked. In the SS (self-diagnostic) data for the idle speed control at the beginning of the thread, you can already see a larger deviation in fuel injection quantity for cylinder 4, which is still within the acceptable range, but it indicates that one of the high-pressure pumps may not be sealing properly.
Best regards.
tom
Audi SQ5 8R Cvub
Translated on 11-08-2026, 0:25.
Back to top Profile PM Email
gtikasper
Post05-10-2013, 10:34    Subject: Quote
The tandem pump was replaced, but the problem remains unchanged.
The power distribution elements (PDEs) were ultrasonically cleaned and resealed.
I now need information to configure the PDE (presumably a specific device or system), but I can only find the technical article about the 1.9L PD engine.
Best regards, Melli.
Translated on 11-08-2026, 0:26.
Post05-10-2013, 13:22    Subject: Quote
I now need information to set up the PDE, but I can only find the technical article about the 1.9L PD.
This is essentially the same principle as with the 1.9 PD engine.
They are rotated 180 degrees back from the lower stop.
Torque specification for nozzle attachment:
Level I = 3 Nm.
Level II = rotate 90 degrees.
Level III = Rotate 180 degrees further.
Important: Tighten evenly and carefully, otherwise the nozzle will move back and forth during tightening.
Tighten the pivot lever shaft to 20 Nm and then rotate it an additional 90 degrees.
Sequence --> alternating from the center outwards.
The screws for the pressure discs and the pivot lever shaft need to be replaced.
Translated on 11-08-2026, 0:28.
gtikasper
Herbert likes this.
Post05-10-2013, 16:46    Subject: Quote
Thank you for the information.
The PIDs are now reset, and the Octavia started again.
It's now clearly running on all four cylinders.
The test drive was successful, and the jerking/stuttering is completely gone.
We'll check how easily it starts and runs when it's cold tomorrow.
We haven't found the source of the water leak yet. After pressure testing the system, it held the pressure of 1.5 bar for over 2 days. We will pressure test it again while it's warm to see if it might be the cylinder head.
Here's the solution to the problem you were experiencing:
The PDES has been cleaned and resealed.
Thank you all for the great help and support!
Translated on 11-08-2026, 0:31.
gtikasper
Post08-10-2013, 21:13    Subject: Quote
Another update.
No more starting problems and no more white smoke.
It's running better than ever. The engine is noticeably improved, and the top speed has suddenly jumped to 225 km/h according to the speedometer icon_wink.gif.
I'll check the water consumption after about 600 kilometers.
Regarding the costs:
"Poetry collection - €35, not for Skodas."
VW ultrasonic cleaning service - €15. Coffee jar included.
(We expanded them ourselves.)
Tilt lever tailshaft screws and Pde screws together - €25 at VW.
Melli
Translated on 11-08-2026, 0:33.
Post08-10-2013, 21:28    Subject: Quote
Okay and thank you for the feedback icon_wink.gif.
For the sake of clarity, let's close this discussion here. If anything else comes up, please send me a private message.
Translated on 11-08-2026, 0:34.
Post09-10-2013, 6:44    Subject: Quote
Please forgive me, Autoservice, for opening this again icon_wink.gif.
I would also find it interesting for other readers to know if pa-mm6 or gtikasper were able to identify the cause of the problem (e.g., brittle/cracked seals, etc.) based on the expanded PDE, seals, or ZK (presumably a component), and whether any rework of the sealing surfaces was necessary.
Translated on 11-08-2026, 0:35.
No new posts Wastegate actuator for turbocharger stuck. Solved Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Octavia 1.8T TDI BMM: Power Loss Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Skoda Octavia 1U: Change dashboard illumination to white Troubleshooting & Guides
This topic is locked, you cannot edit or reply. Solved - Problems with Automatic Transmission Touareg 5R On-Board Diagnostics (OBD)
No new posts Octavia 1Z VCDS Issues: Troubleshooting Guide On-Board Diagnostics (OBD)
No new posts Solved 90% BNS (BCM) T5.2 MDI and FSE coding? On-Board Diagnostics (OBD)
This topic is locked, you cannot edit or reply. Engine Diagnostics: 1.6D/TD Solutions Diesel Engine Technology
