02-09-2013, 8:07 Subject: VCDS 11.11.5 is outdated, VCDS: Software is outdated |
Unfortunately, the new VCDS release was not completed in time. The messages stating that VCDS 11.11.5 is outdated can be ignored, as the functionality of the program is not affected by this.
New orders will be delivered with software version 11.11.6. Updates to the upcoming release will be provided as usual, free of charge, or via the automatic update mechanism of VCDS.
Best regards, Rainer
Profile PM WWW Garage |
05-09-2013, 15:40 Subject: VCDS 11.11.5 is outdated, VCDS: Software is outdated |
Dear Customers, Individuals who might be interested,
Please choose between the first or second option in the red text.
It's not helpful to make phone calls and, even worse, to show up uninvited at my doorstep when I've just arrived minutes before and haven't even had time to use the restroom.
Thank you!
| Description: |
Tja, was nun? Flenn, flenn, flenn... große Katastrophe für einige.
Zielführend: Meldung wegklicken und mal nachschauen, ob es ein Update gibt. Wenn nicht: Nicht herumflennen und abnerven, sondern bitte etwas Geduld. Danke. |
| File size: |
49.18 KB |
| Viewed: |
14721 times |
06-09-2013, 5:27 Subject: VCDS 11.11.5 is outdated, VCDS: Software is outdated |
Improvement suggestions:
1. Adding an "Don't show this again" option in the speech bubble, so that only one click per release is needed to disable it.
or
2. Automatic hiding of information after ~ 3 seconds and release of normal menu functions without requiring the user to click.
or
3. Display the information with forced clicks only for ~ 5 starts from VCDS - after that, most users should understand what it's about. Optionally, starting from the 6th. Automatic switching to Solution 2 with the outdated VCDS version.
Profile PM Garage |
Autoservice Profi-Schrauber
06-09-2013, 12:31 Subject: VCDS 11.11.5 is outdated, VCDS: Software is outdated |
Quote: | 2. Automatic hiding of information after ~ 3 seconds and release of normal menu functions without requiring the user to click.
or... |
From my point of view, the entire function is unnecessary. One can clearly see the effect.
A note in the initial window "please regularly or occasionally check the shop for updates" is perfectly sufficient.
Conversely - if someone is unable to click a simple message, they haven't understood anything and are unfortunately completely overwhelmed by the subject matter.
Blackfrosch Schrauber
18-10-2013, 9:13 Subject: VCDS 11.11.5 is outdated, VCDS: Software is outdated |
That probably has a reason:
Because there are unfortunately also "copies" of VCDS that only "function" up to a certain version. Then it is also good that this message comes in the way it does.
It was shocking to see what was being sold on the used market as a "legitimate" VCDS.
It should probably be feasible to check the software every 3 months for a new version, given its quality. Otherwise, we follow what Auto Service says.
teileklaus Schrauber
Joined: 12/30/2006 Posts: 2643 Karma: +12 / -0 Location: Obrigheim 2005 Volkswagen Premium Support
22-11-2013, 10:42 Subject: VCDS 11.11.5 is outdated, VCDS: Software is outdated |
Where is the problem?
I saw this once and clicked away.
I checked for updates the second time, but there was nothing new. Okay.
the 3rd Clicked away.
Now the solution has been received.
I wouldn't have even asked about this if it hadn't completely stopped working.
Klaus
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Profile PM Email Garage |
