Battery check with VCDS
Post04-12-2013, 16:19    Subject: Battery check with VCDS Quote
In freezing temperatures, it's a good idea to check the battery's function before starting problems arise.
Many vehicles already have a battery management control unit, and with our VCDS, you can check the detailed condition of the vehicle's battery.
Besides the voltage (which is highly dependent on the specific consumers), it is also interesting to consider the "battery health," "battery aging," and "battery state of charge."
The "Energy Balance" indicator shows whether the battery was primarily charged (positive value) or discharged (negative value) during the last trip.
A low internal resistance allows for high starting currents with minimal voltage drop across the battery. A rapidly increasing internal resistance towards the end of a battery's lifespan often indicates that it is nearing the end of its useful life.
Typical values are in the range of a few milliohms, depending on the type and capacity of the vehicle's battery.
Battery check with VCDS - Batterie-Check-VCDS-RKS.flv
 Fahrzeugbatterie mit VCDS prüfen.
 File size:  238.77 KB
 Viewed:  23405 times
No new posts VCDS: Resetting DSG Transmission Settings Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Brake Bleeding with VCDS: A Complete Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Battery Status with VCDS Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS 26.9.0 Update: SFD Now Available in German Version On-Board Diagnostics (OBD)
No new posts VCDS 11.11.5 is outdated, VCDS: Software is outdated On-Board Diagnostics (OBD)
No new posts VCDS-RKS 12.12.2: Update & Features On-Board Diagnostics (OBD)
No new posts VCDS-RKS: Version 11.11.2 Update & Features On-Board Diagnostics (OBD)
