Passat: 1Z-TDI springt nur stark verzoegert an | Posts 16+
Go to page: Previous  1, 2
Karma: +1344 / -0   Thank you, like it!
Post04-12-2013, 0:08    Subject: Quote
Okay, let's not dwell on all the potential problems with this old car. There was or is a vacuum issue in the tank, possibly related to a loss of power, and starting problems when the engine is cold. Nevertheless, the car, including the engine, passed the technical inspection eight weeks ago, and is now heading to Sweden.
Sure, here's the translation:
"Best regards," or "Sincerely,".
Translated on 08-10-2026, 13:26.
Karma: +590 / -0   Thank you, like it!
Post05-12-2013, 1:36    Subject: Quote
Hi!
Oh, yes, the issue of the ESP running out of power is also a concern. I didn't think of that right away.
I've installed check valves in fuel lines in emergency situations like that before.
For older, well-worn T4s, this sometimes helped them last up to 100,000 km until the end of their lifespan.
There's a check valve at VW that's originally installed in a T3 with a gasoline engine.
It is fuel-resistant, and based on experience, the flow rate is also sufficient.
Translated on 08-10-2026, 13:27.
Post05-12-2013, 10:19    Subject: Quote
The problem with the fuel ventilation seems to be solved. The car is already rolling towards Sweden.
There's no point in speculating about what else might be missing from the engine. If there are any more problems, the driver will let us know, and we'll get it running again.
Translated on 08-10-2026, 13:28.
DieselBär30x
Avatar-DieselBär30x
Post05-12-2013, 21:37    Subject: Quote
Hello everyone!
@HerBärt: The problem is NOT solved, not even seemingly, or were you able to discern Spati's resolution/conclusion between the lines?
He "wrote" that the vehicle is currently out of his reach and that he will provide further feedback later.
And it stays open like this for so long! *grumble*
Spati started the thread and is old/mature enough to close it again, if necessary, and in a way that is appropriate. icon_rolleyes.gif
Best regards from Munich!
Translated on 08-10-2026, 13:29.
Karma: +1099 / -0   Thank you, like it!
Post05-12-2013, 22:45    Subject: Quote
I had been communicating with Herbert via private message throughout the day, and I would have been able to accept the temporary closure.
Last night, I received a text message: the Passat, along with its passengers and luggage, has arrived in northern Sweden. Cleaning the fuel tank cap helped – the hissing sound when opening it is gone, and it now starts after about 4-5 seconds. It's better than before, but not as good as I would expect from newer vehicles. The daytime temperatures around -7 degrees Celsius and nighttime temperatures around -16 degrees Celsius haven't stopped it, it's still running. It's not far from reaching 700,000 kilometers. That milestone will be reached during a ski trip in a few days.
Translated on 08-10-2026, 13:31.
DieselBär30x
Avatar-DieselBär30x
Post05-12-2013, 22:52    Subject: Quote
Hello Spati!
Personally, I don't believe the fuel cap is the (main) cause, however, the 4-5 seconds of engine running time at temperatures between -16°C and -7°C (possibly also due to a faulty glow plug system?) seems quite acceptable considering the extremely high mileage.
Decide yourself whether you want to close this topic as resolved or not.
Translated on 08-10-2026, 13:32.
No new posts Document A4, interior cools down too much Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts TDI engine starts poorly Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Engine won't start, Mj 1999 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat Smoking: Troubleshooting & Repair Guide Upload
No new posts Passat 3B: Excessive Smoke Under Load - Troubleshooting Diesel Engine Technology
No new posts Passat 1.9 TDI: Hard Starting Problems & Fixes Diesel Engine Technology
No new posts Passat 2.0 TDI: Won't Start - Troubleshooting Diesel Engine Technology
