Increase Engine RPM with VCDS (Boost Leak)
alevuz
Karma: +32 / -0   Thank you, like it!
Post11-03-2014, 11:05    Subject: Increase Engine RPM with VCDS (Boost Leak) Quote
My Turbo (Golf) has been making a loud noise under load since yesterday - it just started suddenly when I accelerate.
When the device is stationary and unloaded, there's naturally nothing to hear... (or maybe a slight hissing sound - I might just be imagining it).
Is there a way to use VCDS to set the engine speed to approximately 2300 RPM for troubleshooting, and then hold it steady so I can get under the car and locate the leak?
There's some oil leakage visible at the transition point to the LLK (likely referring to a specific component), and the seals are approximately 215,000 km old. Some of the connecting pieces don't feel quite as tight as they should.
Turbo has approximately 25,000 kilometers on the odometer.
Thank you very much for the information.
SG
Alevuz.
Touareg V10 TDI (AYH)
Translated on 13-09-2026, 15:58.
Post11-03-2014, 11:34    Subject: Increase Engine RPM with VCDS (Boost Leak) Quote
By default, it increases the RPM during the N75 test to around 1500 RPM. During this process, the VTG (Variable Turbine Geometry) is alternately closed and opened, which also results in a slight build-up of boost pressure. Maybe this is enough for you.
Otherwise, reboot the system.
Translated on 13-09-2026, 16:00.
Post11-03-2014, 11:38    Subject: Increase Engine RPM with VCDS: Tuning Guide Quote
alevuz wrote:
Is there a method to bring the engine speed to approximately 2300 RPM using VCDS for troubleshooting and keep it there so I can get under the car and locate the leak?
2300 RPM probably won't be possible (I'm sure of it with the EDC15).
But try the basic setting in the MWB 11: For (the not-so-old) EDC15 systems, the engine is brought to 1400 rpm, and the turbocharger is activated in a 10-second cycle to achieve maximum boost pressure. And approximately 0.1 - 0.2 bar of pressure whistling out of leaks is already quite noticeable icon_wink.gif.
Edit: The previous poster was faster...
Translated on 13-09-2026, 16:01.
alevuz
Post11-03-2014, 11:57    Subject: Increase Engine RPM with VCDS (Boost Leak) Quote
Thank you both - I'll try it out tonight!
SG
Alevuz.
Translated on 13-09-2026, 16:02.
Post11-03-2014, 14:12    Subject: Increase Engine RPM with VCDS (Boost Leak) Quote
Without any load, a significant amount of boost pressure will not be generated. My suggestion would be to install plugs in the charge air path and pressurize it to 1.2 bar. As a quick solution, you could use wood drill bits from a hardware store to cut out a thick wooden disc, drill a hole in the center, and insert a tire valve. I believe there were other construction guides and dimensions available in the forum for this (use the search function).
Caution: Risk of injury if the plugs are not securely fitted. icon_exclaim.gif
Translated on 13-09-2026, 16:03.
jarobaldu
Karma: +40 / -0   Thank you, like it!
Post12-03-2014, 11:48    Subject: Increase Engine RPM with VCDS (Boost Leak) Quote
"Use rubber stoppers for drain pipes, available at hardware stores, with a diameter of 40/50mm."
http://www.stabilo-sanitaer.de/ht-rohr-muffenstopfen-dn110-htm-stopfen-abwasserrohr-abflussrohr/a-436616/?ReferrerID=7&/?utm_source=google&utm_medium=cpc&utm_content=base&utm_campaign=shopping&gclid=CMKgg8vbjL0CFWvjwgodI5wATg
Then drill a hole and insert the Schrader valve.
Adrian.
AUDI A6 C4 1995 ABC/CRD
Fiat 124 Spider, Bj. 80
Translated on 13-09-2026, 16:04.
No new posts Document A6 4B, Fog lights leaking Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Passat 3B2 Achsmanschette undicht Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts T6 Windshield Washer Fluid Leaking, Washer Fluid Tank Dam... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VAG-COM: Increase Engine RPM for Throttle Search On-Board Diagnostics (OBD)
No new posts Heating output as a function of engine speed Transmission, Chassis, Body & Interior
No new posts Engine Speed Sensor | 00801 Diesel Engine Technology
No new posts RS3 2022 - Incorrect engine speed reading in DSG transmis... On-Board Diagnostics (OBD)
