Oil Leak or High Oil Pressure?
diesler
Post08-04-2014, 18:33    Subject: Oil Leak or High Oil Pressure? Quote
I performed an oil change on my Golf VI TDI with a 77 kW engine – not for the first time. This time, the engine is leaking oil. Replacing the sealing ring didn't help much, but tightening the filter housing cover to 50 Nm instead of 24 Nm helped somewhat.
My question: Could the oil pressure be too high due to a defect? What could be the possible causes?
A fault query using VCDS-RKS shows no errors; everything is working correctly.
Greetings.
diesel
Translated on 24-07-2026, 7:47.
Post08-04-2014, 23:38    Subject: Oil Leak or High Oil Pressure? Quote
What engine (model code) are we talking about?
I find it hard to believe that the oil pressure is too high. Are you using the correct filter and have you replaced the sealing ring?
Possibly, the lid has a crack or damage above the sealing ring, which means it is now only sealed by the flat surface at the threaded connection. Normally, they seal as soon as the O-ring contacts the cylindrical surface when being screwed in.
Translated on 24-07-2026, 7:49.
diesler
Post09-04-2014, 9:55    Subject: Oil Filter Housing Leak: Causes & Fixes Quote
I'm glad it will be related to the oil filter housing. I'll check that more closely now. The engine code is: CAYC.
I'll let you know as soon as I find out more.
Best regards.
Diesler.
Translated on 24-07-2026, 7:50.
Post09-04-2014, 10:46    Subject: Oil Leak or High Oil Pressure? Quote
Was definitely the old seal removed?
It has happened before that two rings were placed on top of each other.
Translated on 24-07-2026, 7:51.
diesler
Post09-04-2014, 10:59    Subject: Double O-Ring: Benefits & Applications Quote
Hi Roger,
Definitely do not stack two O-rings on top of each other.
Best regards.
diesel
diesler
Post09-04-2014, 14:08    Subject: High Oil Pressure? Troubleshooting & Causes. Quote
Hello Uncle BM,
Hello Roger,
I tightened the oil filter housing cap a bit more, and it seems to be sealed now. I used 50 Nm of torque; hopefully, that's not too much.
The filters and seals are original VW replacement parts. I would prefer a softer and wider sealing ring or a permanently elastic sealant. If you have anything like that available, I'd be interested in trying it.
Thank you for the tip that it shouldn't be due to excessive oil pressure; that has helped me. icon_smile.gif
Best regards.
diesel
Translated on 24-07-2026, 7:53.
klahaui
Avatar-klahaui
2019 Volkswagen Golf
Post09-04-2014, 14:56    Subject: Oil Leak or High Oil Pressure? Quote
Was the sealing ring lightly lubricated with oil beforehand?
Translated on 24-07-2026, 7:54.
Post09-04-2014, 17:26    Subject: Oil Leak or High Oil Pressure? Quote
I tightened the cover of the oil filter housing a little more, and now it seems to be sealed. It's 50 Nm; hopefully, that's not too much.
I wouldn't leave it like that. It's probably just a matter of time before it starts leaking again.
As I said, the O-ring seals, not the lip of the lid!
diesler
Post10-04-2014, 15:19    Subject: Oil Leak or High Oil Pressure? Quote
I've done many oil changes before, but this is only the second one for a diesel engine. My plan is to have another filter change after an oil pressure measurement. I'm curious to see if everything will be normal then.
It was nice to meet some of you diesel mechanics.
Best regards.
Diesler.
Translated on 24-07-2026, 7:55.
Karma: +590 / -0   Thank you, like it!
Post10-04-2014, 19:45    Subject: Oil Leak or High Oil Pressure? Quote
Hello!
I can report that I have experienced similar problems multiple times with cheap oil filters.
However, the O-rings included were also visibly of a somewhat unusual quality.
Translated on 24-07-2026, 7:56.
diesler
Post12-04-2014, 15:32    Subject: Oil Leak or High Oil Pressure? Quote
Hello Steffen,
Yes, it's probably the sealing ring.
Greetings,
diesel
Translated on 24-07-2026, 7:57.
No new posts ATF oil leak on 74 kW TDI engine Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Oil Leak MKB AKF: Oil Level Sensor Problem Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document 1J 4Motion, Oil Leak on Haldex Coupling Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts TDI AWX Oil Leak: Causes and Solutions Diesel Engine Technology
No new posts Stop Oil Leaks: Repair & Prevention Diesel Engine Technology
No new posts Turbocharger Oil Leak: Causes & Fixes Diesel Engine Technology
This topic is locked, you cannot edit or reply. Oil Leak: AFN/Turbo Exhaust Problems Diesel Engine Technology
