What interface is required
Corradoman
Post14-06-2014, 9:26    Subject: What interface is required Quote
Hello everyone
What interface do I actually need if I want to use it across different brands but also across different software?
For my old car, my old KKL diagnostic interface is sufficient. (even with RS232 connector) icon_lol.gif
This, however, makes it impossible to read other older vehicles (e.g., Ford, Mitsubishi, Nissan, etc.) because the aftermarket software does not recognize the interface, and therefore, a connection to the control unit naturally fails.
Only VCDS recognizes my interface, but of course it doesn't work with third-party brands.
Does there exist such a "universal interface" that works with other software?
Second question:
Was was the CAN system compatible with, backwards?
(so, dass mit einem CAN-Interface (KKL) ausgelesen werden kann)
94er VW Corrado 16V für die sonnigen Tage im Jahr. Mein Alltags-Fahrzeug:
Golf IV Variant TDI,Bj 2000 mit ALH-Motor und bescheidener Leistung von 90PS -> verkauft
Touran "Freestyle" Modell 2010, BSE-Motor und niedlichen 102PS -> verkauft
Jetzt 2013er Nissan Qashqai 110 Diesel-Pferde
Jan6K
Avatar-Jan6K
Post14-06-2014, 9:31    Subject: What interface is required Quote
Regarding the second question:
http://shop.dieselschrauber.de/vcds-obd2-profi-diagnose-kkl-can-p-46.php
The MicroCAN interface cannot do that.
Jan
1Z5 CFHF / AHB H4D
Wiesel
Post14-06-2014, 11:07    Subject: Re: What interface is required Quote
...This will make it impossible, for example, to read other older vehicles (Ford, Mitsubishi, Nissan, etc.) because the aftermarket software does not recognize the interface, and therefore, a connection to the control unit naturally fails.
Furthermore, with older vehicles, the fact that some parts are {MISSING/NOT AVAILABLE} adds to the difficulty.
Use ISO 9141 (K-Line) as a data interface, which means using completely different hardware.
need.
There are systems (Bosch KTS, Gutmann, Launch, ...) that operate in this direction.
Here is a comparison of DEKRA: http://files.vogel.de/vogelonline/vogelonline/files/2230.pdf
Hi Micha
Corradoman
Post14-06-2014, 11:51    Subject: What interface is required Quote
Thank you for the responses.
No, it shouldn't be too expensive either, as I'm using it purely for personal, hobby-related purposes, and I'll never recoup the costs.
I just want to occasionally check older cars (among friends) and sometimes newer ones (e.g., my current car) for errors. (Error diagnosis)
For my old "top-of-the-line" car, I am perfectly familiar with my interface, but this does not work with other software, and therefore also not on other (older) vehicles.
Maybe I should actually go with 2 cheaper interfaces, one for KKL and one for CAN-bus.
klahaui
Avatar-klahaui
2019 Volkswagen Golf
Post15-06-2014, 15:11    Subject: What interface is required Quote
For all vehicles that are not VAG, I have been using *** or also **** for quite some time.
So far, I've been able to work on everything, whether it's a Ford, BMW, Toyota, old or new.
Software was intended for Delphi or something similar.
I am satisfied.
Staged diagnosis, training, or real-time data are also no problem.
Greetings
EDIT @AutoserviceViewing profile: Autoservice: As far as I'm aware, the version costs around 2,500 EUR.
Advertising for cloned tableware, please elsewhere, not here icon_exclaim.gif
Post16-06-2014, 11:19    Subject: What interface is required Quote
If you aim for 100% diagnostic depth, you can only achieve this with VCDS or, of course, a VAG tester.
klahaui
Avatar-klahaui
Post16-06-2014, 12:18    Subject: What interface is required Quote
@autoservice
That's what I didn't know either. I purchased this item privately.
Corradoman
Post16-06-2014, 15:37    Subject: What interface is required Quote
Autoservice wrote:
If you aim for 100% diagnostic depth, you can only do it with VCDS or, of course, with a VAG tester.
Hello
As already written, for my "old" Renner, I used the KKL interface with the VCDS from Rainer. With this, I am more than adequately equipped for this vehicle.
I am also aiming to be able to read fault codes in other vehicle brands (outside of the VAG group) for people I know.
The goal is not to perform a detailed component diagnosis, or to activate or trigger specific actors.
No new posts VW Crafter: Second battery not charging Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS: HEX-USB CAN adapter not found after update General Tips
No new posts Diese Funktion benötigt ein lizensiertes Interface On-Board Diagnostics (OBD)
No new posts Welches Interface für A4 2,5 TDI V6 BJ:2005 On-Board Diagnostics (OBD)
No new posts USB Interface not recognized On-Board Diagnostics (OBD)
No new posts Russia Problems: Urgent Help Needed! Diesel Engine Technology
