Steering Assist Control Unit Error
Klausel
Post04-07-2014, 20:20    Subject: Steering Assist Control Unit Error Quote
Polo 9N, manufactured in 2006, engine code AXR.
We are experiencing a power steering failure with the following error message:
Address 09: Central Electronics
Label file: RKS\6Qx-937-049-C.lbl
Part number: 6Q1 937 049 D
Component: 00BP BN-SG. 1S34
Encoding: 09646
Operating number: WSC 31414
VCID: 3C73468D2C30C9FE87F-5102
"One error found:"
01309 - Steering assist control unit (J500)
49-00 - No communication.
Can someone tell me where I can find this control unit?
Thank you.
Best regards, Klaus.
Polo 6R, TSI 110 PS
Translated on 01-09-2026, 11:46.
Wiesel
Post04-07-2014, 20:43    Subject: Steering Assist Control Unit Error Quote
I'm afraid there's a problem with the hydraulic pump icon_confused.gif.
 File size:  188.49 KB
 Viewed:  14991 times
Translated on 01-09-2026, 11:47.
Klausel
Post04-07-2014, 21:08    Subject: Steering Assist Control Unit Error Quote
Right now, the steering is working again (at least when the car is stationary), and the warning light is off.
Can VCDS be helpful in addressing this issue? Are there any relevant diagnostic trouble codes (DTCs)?
EDIT: Thanks for the graphic, I hadn't seen it before.
Polo 6R, TSI 110 PS
Translated on 01-09-2026, 11:48.
Post04-07-2014, 22:21    Subject: Steering Assist Control Unit Error Quote
Check the cable in the area of the left bracket near the splash guard at the lowest point. Cut open the black sheathing there and carefully inspect the two twisted CAN cables and the remaining insulation of the cables. If these are swollen due to constant moisture, the copper will be oxidized. In such cases, the problem is often a lack of communication with the steering assist control unit or a voltage that is too low in the memory.
Sometimes, the Linkhilfe control unit is malfunctioning.
Translated on 01-09-2026, 11:49.
No new posts ABS Control Module 6X0 907 379B - Error Code 00668 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P0148 - Fuel Supply Malfunction General Tips
No new posts Skoda Octavia RS: Adjust Steering Control Unit On-Board Diagnostics (OBD)
No new posts Golf 5 - Steering assistance control unit - Implausible s... Transmission, Chassis, Body & Interior
No new posts Polo 6R1: Steering Assist Control Unit Coding On-Board Diagnostics (OBD)
No new posts Skoda Fabia Steering Assist Error On-Board Diagnostics (OBD)
