Bosch ABS/ESP 5.3: Basic Settings & Configuration (Solution)
Post11-08-2014, 20:57    Subject: Bosch ABS/ESP 5.3: Basic Settings & Configuration Quote
The brake system bleeding is performed by controlling the ESP hydraulic pump (V156). To do this, access the ABS/ESP control unit via VCDS (control unit address 03) and then select the basic settings mode.
Select block 002, then the hydraulic pump will be activated for 10 seconds.
Translated on 15-10-2026, 13:49.
Ratings - Bosch ABS/ESP 5.3: Basic Settings & Configuration
No new posts Basic settings for Teves Mark 20 IE / MK20 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Basic Settings for ABS/ESP Teves Mark 60 / MK60 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Bosch VP44 pump control unit repair Troubleshooting & Guides
No new posts T4 Control Unit Basic Settings On-Board Diagnostics (OBD)
No new posts VP37 Adaptations: Settings & Configuration Options On-Board Diagnostics (OBD)
No new posts HEX-NET: Reset to factory settings On-Board Diagnostics (OBD)
No new posts VCDS - Some options are missing under Basic Settings On-Board Diagnostics (OBD)
