Symbol Auto mit Schlüssel drin | Posts 32+
Go to page: Previous  1, 2, 3
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post07-09-2014, 20:07    Subject: Quote
Hello Guste, thank you for the tip.
ebay.de/ws/eBayISAPI.dll?ViewItem&item=371137914262
I was actually considering that, although the error hasn't reappeared.
"But this is only supposed to fit the 2-liter version, even though the number with the 'AF' suffix matches the one printed on mine."
Are there any difficulties adapting to the 1.9 TDI engine?
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Translated on 14-07-2026, 23:17.
Post07-09-2014, 22:24    Subject: Quote
teileklaus wrote:
but this is supposed to only fit the 2-liter bottle, even though the number with the "AF" suffix matches the one printed on mine.
Gibt es beim 1,9 TDi dann Anpassungsschwierigkeiten?
If you have a part with the same part number now, then the new one will also fit. I am not aware of any dependency between the engine and the steering column control unit.
Most likely, the seller simply indicated which donor vehicle the control unit came from.
Greetings.
Sure.
Here is the translation of the text from German to English:
"Guste" means "gust" in English. It refers to a sudden and strong gust of wind.
Translated on 14-07-2026, 23:18.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post08-09-2014, 8:14    Subject: Quote
Okay, then let's put it in. Thank you.
Translated on 14-07-2026, 23:19.
No new posts Automotive Technology: Topics & Resources Technical Articles
This topic is locked, you cannot edit or reply. Oil stain under the car - transmission fluid or brake fluid? General Tips
No new posts Golf V - Automatic Lock and Automatic Unlock On-Board Diagnostics (OBD)
No new posts - Door open - symbol in the instrument cluster Transmission, Chassis, Body & Interior
No new posts Is there something wrong? Transmission, Chassis, Body & Interior
No new posts What type of water pump is installed in the 2.0 TDI engine? Diesel Engine Technology
