Fabia Speedometer 2003 ASY
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
chli1976
Post09-09-2014, 16:47    Subject: Fabia Speedometer 2003 ASY Quote
Here's a Fabia where the speedometer isn't working, and it's showing this error code:
01086 - Speedometer sensor (G22).
06-10 - Signal too large - Sporadically.
I started by performing an actuator diagnosis, and it worked.
Then I checked the power supply of the G22, and it was also okay.
The signal cable to the combination unit was checked for continuity and is also okay.
Then I installed a new G22, but it still doesn't work.
I then checked the signal with the oscilloscope, and it consistently reads around 10V, even when the engine is running.
I then removed the sensor again and looked inside the transmission. There are indentations, approximately 1 cm wide, every 2-3 cm. So, it should fit.
Finally, the signal is simulated using a function generator, and the speedometer works.
Then I ran a milling head with a diameter of about 2cm, along with some recesses, over the extended sensor using a drill, but nothing changed. Perhaps the profile isn't correct.
I can't quite imagine that the new sensor is broken. The speedometer went haywire when I stalled the engine in 3rd gear without using the clutch. The owner also said it should display something after a longer drive, but sometimes it shows too much.
VCDS
Translated on 25-09-2026, 15:57.
Post10-09-2014, 9:16    Subject: Fabia Speedometer 2003 ASY Quote
Then I checked the power supply of the G22, and it was also OK.
Checked for short circuits between each other?
Are the connector connections okay?
Translated on 25-09-2026, 15:59.
chli1976
Post10-09-2014, 13:02    Subject: Fabia Speedometer 2003 ASY Quote
It was due to the power supply of the G22. I didn't test it under load because I don't have a Y-connector.
I pierced the positive cable, and under load, it dropped to 2 volts.
VCDS
Translated on 25-09-2026, 16:00.
No new posts Document A2 8Z0 MJ 2003, noises from the front of the car Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A2 8Z0 MJ 2003, broken rear spoiler Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku A2 8Z0 MJ 2003, Hands-free device malfunction Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Adjust Speedometer: Calibration & Troubleshooting On-Board Diagnostics (OBD)
No new posts Speed display in the radio screen on a VW Golf 5? Transmission, Chassis, Body & Interior
This topic is locked, you cannot edit or reply. Audi A3 2.5 TDI Engine Noise - 2003 Diesel Engine Technology
No new posts Driver's side fender liner, 3BG model, year 2003 Upload
