Passat 3BG BGW, Coughing in the intake system/ Oil consumption is increasing
Mugel1983
2004 Volkswagen Passat
Post25-08-2014, 23:59    Subject: Passat 3BG BGW, Coughing in the intake system/ Oil consumption is increasing Quote
Hello dear community,
After a long search on the www, I'm starting a thread here to share my solution to the puzzle icon_rolleyes.gif
Vehicle:
Passat Variant 3BG
MKB: BGW with DPF
KM 205.000km
Regarding my problem, for the past 2 days, I've been hearing a loud "popping/knocking" sound (however you would describe it) coming from the engine compartment.
I can't say exactly how long it has been, as I had been driving for approximately 60 km on the main road before I stopped and noticed it, and it became noticeably louder as I pressed the accelerator.
I stopped immediately to investigate, but at that time I found nothing.
Upon arriving home, I checked the oil level, and to my surprise, there was almost 1 liter over the normal level!?!
Initially, I thought the noise was coming from the area of the air filter. After checking the intake hoses for leaks, I noticed that the noise was still present even after removing the hose after the turbo and LLK (only the AGR and intake bridge remained). This indicates that the noise is coming from the engine!?!
My question is therefore, what is this noise, and what does it have to do with the rapidly increasing engine oil (PD-element defective)? If so, how can I best check it?
No fault codes present. The engine is running normally and smoothly on all 4 cylinders. There is no noticeable power loss or any jerking!
Last oil change before 10,000 km. So far, very little oil consumption has been detected. Oil change intervals are approximately every 15,000 km since I have owned the vehicle.
I have made 2 videos regarding the noise, one with the intake system closed and the other with only the AGR valve connected.
Also a Log MWB 13
Passat 3BG BGW, Coughing in the intake system/ Oil consumption is increasing - IMG_1528.3gp
 Offener Ansaugtrakt vor AGR
 File size:  644.14 KB
 Viewed:  1659 times
Passat 3BG BGW, Coughing in the intake system/ Oil consumption is increasing - IMG_1527.3gp
 Geschlossener Ansaugtrakt
 File size:  988.21 KB
 Viewed:  1596 times
LOG-01-013-015-xxx.xls
 File name:  LOG-01-013-015-xxx.xls
 File size:  22.5 KB
 Downloaded:  437 times
VW Passat 3C ; MKB: BKD Bj. 2008
VW Touran 1T1 ; MKB: BMN Bj. 2007
VW T5 Multivan ; MKB: CFCA Bj: 2011
mullemaus
Post26-08-2014, 0:09    Subject: Passat 3BG BGW, Coughing in the intake system/ Oil consumption is increasing Quote
'Engine knocking' in the intake tract sounds like faulty hydromechanical systems, camshaft issues, etc. icon_wink.gif
Post26-08-2014, 21:51    Subject: Passat 3BG BGW, Coughing in the intake system/ Oil consumption is increasing Quote
Remote diagnosis is always difficult... maybe I have some wax in my ears.
Mugel1983
Post05-09-2014, 21:45    Subject: Passat 3BG BGW, Coughing in the intake system/ Oil consumption is increasing Quote
A few days ago,
Now, I measured the compression with amazement, and achieved around 29 bar on all cylinders.
Then remove the valve covers to inspect the pistons. The 3 pistons can be pushed in approximately 3-4 mm without much effort when in the relaxed state.
I think this explains the knocking, because a piston can be made to knock if you push it back and forth!?!
And the valves are no longer working properly.
One question remains open: could this explain the excessive/motor oil dilution?
Post05-09-2014, 22:33    Subject: Passat 3BG BGW, Coughing in the intake system/ Oil consumption is increasing Quote
One question remains open: could this explain the high or the engine oil dilution??
I don't think so.... Perhaps the DPF is quite full of ash, and the additive for regeneration is being consumed, which means that active regeneration occurs more frequently than normal.
How much ash is there in the filter?
Mugel1983
Post09-09-2014, 9:39    Subject: Passat 3BG BGW, Coughing in the intake system/ Oil consumption is increasing Quote
I will check it again once it's back up.
Can someone please provide the torque specifications for the cam followers (where the bearing races are located) and the rocker arms (pump-nozzle element)?
Den Rest habe ich.
Mugel1983
Post14-09-2014, 19:42    Subject: Passat 3BG BGW, Coughing in the intake system/ Oil consumption is increasing Quote
So, after I over-tightened a screw on the cylinder head, it had to be removed and drilled out, with a new thread installed. icon_cry.gif
Cylinder head gasket + new bolts, all gaskets, hydraulic lifters, bearing shells, camshaft.
OT Setting checked perfectly after 4-5 post-checks!
But somehow, I don't have the same performance as before. I re-measured the compression, and the results are still at peak values.
MWB 13 indicates on cylinder 4 +2.99????
Possible issue: Head gasket/Wiring harness
Everything is connected, no error codes in the memory.
Post14-09-2014, 20:07    Subject: Passat 3BG BGW, Coughing in the intake system/ Oil consumption is increasing Quote
Pump-Nozzle Element: Incorrect/Not Adjusted, Incorrectly Installed, or Defective. I would check this first.
Post14-09-2014, 23:55    Subject: Passat 3BG BGW, Coughing in the intake system/ Oil consumption is increasing Quote
Sounds: Bleeding is okay... and also the hoses where the boost pressure is?
Mugel1983
Post19-09-2014, 12:16    Subject: Passat 3BG BGW, Coughing in the intake system/ Oil consumption is increasing Quote
Vacuum hoses all properly connected, I replaced a few porous ones.
I have re-adjusted the pump nozzle elements according to the technical articles, and although the seals were not removed, I will be purchasing new ones. I'm wondering why, because I've read a lot that they need to "settle" into the cylinder head. Is it model-dependent?
Let's see if it changes when the seal is replaced. Currently, it still shows -2.99 for Cylinder 4.
No new posts VW Crafter: Second battery not charging Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS: HEX-USB CAN adapter not found after update General Tips
No new posts BLS - Erratic idle when AC is on - and more Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Steuergerät wird nicht mehr erkannt Diesel Engine Technology
No new posts Oil Leak: Increasing Amount, More Loss - Dangerous! Diesel Engine Technology
No new posts N75 Valve Not Activating on VW Passat 2.0 TDI Diesel Engine Technology
No new posts Passat 3B AHU won't start Diesel Engine Technology
