Steffen G Profi-Schrauber
Joined: 10/26/2006 Posts: 2557 Karma: +591 / -0 Location: bei Zwickau
15-04-2015, 19:26 Subject: ALB Adjustment: VW T4 Brake Force Limiter Calibration |
Hello!
With my T4, I have a problem where the rear brakes are applying too much force.
Unloaded. I need to drive it occasionally so the brake discs don't rust, but when I brake hard, it locks up the rear wheels.
That can be quite dangerous, even in the winter.
I looked into this on the T4 wiki, and apparently you need two pressure gauges there. One at the front, showing 50 bar, and one at the back, showing 20 bar, with the axle in a defined position.
It's strange that there are hundreds of these T4 pickup trucks driving around here, but no workshop knows anything about them or has the necessary testing equipment.
Even at VW, the master technician couldn't give me a reasonable answer as to whether they could do it "properly." "I'll have to ask someone, but they're not here this week... I don't even know if we have the equipment for that..."
It appears that the brake force distribution system is still working, but it is likely misconfigured.
Can someone provide some input on this?
I really wanted to do it properly. Grüße, Steffen!
Translated on 12-10-2026, 1:49.
T3Surfer Profi-Schrauber
Joined: 09/17/2004 Posts: 1833 Karma: +34 / -0 Location: Frankurt 2001 Seat Toledo Premium Support
15-04-2015, 20:50 Subject: ALB Adjustment: VW T4 Brake Force Limiter Calibration |
... or was replaced with a fake in the past. I once encountered this with a customer.  They often just get stuck. NA,Gehörlose wie ich können auch Schrauben! Ihr HÖRT ich FÜHLE! T3 TD EX-JX Jetzt 1Z mit 122PS und Renaultgetriebe Golf II TD Bj 84 512Tkm Passi 35I 1Z 468Tkm--> Seat Toledo AHF-- Toledo ARL 477Tkm mit Spritspartuning  99er T4 Syncro-Cross 100800km grad eingefahren
Translated on 12-10-2026, 1:51.
Profile PM Email Garage |
15-04-2015, 20:58 Subject: ALB Adjustment: VW T4 Brake Force Limiter Calibration |
So, everything that moves is easily movable. When you apply the brakes, it also moves slightly.
It was like that at least six months ago, but I should probably double-check tomorrow just to be sure. Grüße, Steffen!
15-04-2015, 21:38 Subject: ALB Adjustment: VW T4 Brake Force Limiter Calibration |
Unfortunately, the term "Hebel gängig" doesn't have a direct or common translation.
The pistons may also be stuck, in which case nothing will happen even if the lever moves. This is more likely to occur if the system is operated at the same level for a very long time. MfG. Michael
Translated on 12-10-2026, 1:52.
Profile PM Garage |
Rüdi Profi-Schrauber
Joined: 03/05/2005 Posts: 1511 Karma: +645 / -0 Location: Nord/Osthessen 2001 Audi A4 Avant Premium Support
16-04-2015, 10:07 Subject: ALB Adjustment: VW T4 Brake Force Limiter Calibration |
Why don't you go to a brake testing station at TÜV & Co. when it's not busy and have your brake values checked? With my last T4, I practically adjusted the BKR (brake force regulator) on the brake roller until the inspector approved it. Sommer: A4 B5 Avant 2,5 TDI Quattro Facelift (AKN silber)
Profile PM Garage |
17-04-2015, 18:13 Subject: ALB Adjustment: VW T4 Brake Force Limiter Calibration |
Hello!
So, the brake force limiter is working; it's at least moving when the brake is applied.
I adjusted the springs to have less pre-tension.
Now, the rear wheels of my car no longer block the gravel parking space.
@Rüdi:
Do you have a braking value for the rear axle when the car is unloaded?
0.9 liters according to the reading on the test bench?
My gut feeling would tell me that. Grüße, Steffen!
Translated on 12-10-2026, 1:53.
19-04-2015, 18:54 Subject: ALB Adjustment: VW T4 Brake Force Limiter Calibration |
Unfortunately, I no longer have the data; I had a document from VW for it, but I lost it.
"90 is definitely too low, I mean, the Multivan had a value of 180 in the back." Sommer: A4 B5 Avant 2,5 TDI Quattro Facelift (AKN silber)
Translated on 12-10-2026, 1:54.
Profile PM Garage |
19-04-2015, 20:01 Subject: ALB Adjustment: VW T4 Brake Force Limiter Calibration |
Hi!
Too bad, well, I'll have to ask the TÜV inspector.
But it was really about the mindset. I drove on the road again yesterday and really slammed on the brakes.
Now I can really put my foot down on it without it getting blocked from behind.
So, things have changed.
I adjusted it by 1 cm on both sides. Grüße, Steffen!
Translated on 12-10-2026, 1:55.
23-04-2015, 18:36 Subject: ALB Adjustment: VW T4 Brake Force Limiter Calibration |
Hello!
Today, I had a lucky opportunity: My father loaded garden waste onto the T4 van.
Unfortunately, because it was a double cab, the entire load was directly on the rear axle.
I drove my car to the brake testing machine at the workshop next door.
Okay, loading:
Front: 3.3, Rear: 2.0.
I took the stuff to the composting facility and got a weight certificate.
That was a payload of 190 kg.
Then we checked the brakes again on the dynamometer, and the rear brakes were reading 1.5.
I already noticed that the regulator was failing when I was on the brake tester.
You can press that pedal as hard as you want, but it won't go above 2.0 or 1.5.
Does anyone have any benchmark values? Do you think I can leave it like this?
Unfortunately, I haven't been able to find any workshops in the area that can properly adjust the brake force limiter.
Neither VW workshops. Grüße, Steffen!
Translated on 12-10-2026, 1:57.
