I recently purchased a Passat 365 (manufactured in 2012) with a CFGB engine and DSG (NJD) transmission. The 4motion system installed in it has...
The vehicle has a Haldex clutch from the fourth generation. Now I want to take it for an inspection, and I would like to have it done at an Audi/VW dealer because of potential warranty claims, mobility guarantee, and excellent service.
Here's my problem:
The Haldex oil needs to be changed, but supposedly without replacing the filter. The filter in the Gen4 is also slightly larger than in previous generations, but in my understanding, it's not designed to last forever. Audi/VW refuses to acknowledge this and claims that there is no replacement filter available for this Haldex system, so it doesn't need to be changed according to the service instructions.
I have a strange feeling about this. Apparently, there's a possibility to order a filter with internal components for €50 from a tuner in southern Germany online.
And now, the burning question:
Why would VW not want to change the filter, when it would be much simpler for them, due to potential liability claims, warranty cases, etc., to have the filter replaced during the regular service? It would be much easier and less problematic for VW if they could also make some extra money for the additional work. Many 4motion users, on the other hand, believe that major problems would arise if the filter were not changed according to VW's instructions. Apparently, Haldex itself specifies a replacement interval of 30,000 km, including filter replacement.
I'm now unsure whether I should purchase the filter from a specialized supplier, which might be expensive, and give the business to Audi/VW, even though the manufacturer (who is ultimately responsible for covering any damage) claims that a replacement is unnecessary?
I can't make sense of this. Does anyone have any idea what the right thing to do is?
Sure, here's the translation:
"Thank you in advance!"
corner nut
PS: I don't think a VCDS scan or something similarly detailed about my car is particularly relevant to this question. However, I'm happy to upload it if you'd like.
Translated on 26-09-2026, 18:18.
