Rear side window modification for Audi C4 Avant?
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
charmilles
Karma: +2 / -1   Thank you, like it!
Post10-07-2015, 15:13    Subject: Rear side window modification for Audi C4 Avant? Quote
Hello everyone,
I'm currently in the process of restoring a 1996 Audi A6 C4 Avant. I have rust on the rear side windows and the adjacent body panels. To achieve the best possible result, I would like to remove the rear side windows. The rubber seals are no longer available, and it seems the side windows are likely glued in place.
How can I best remove the rear side windows without damaging the rubber seal?
Thank you very much...
Translated on 12-07-2026, 9:33.
Post10-07-2015, 18:21    Subject: Rear side window modification for Audi C4 Avant? Quote
I'm not familiar with the exact details of the C4. If you have the ability to place a wire around the outside, behind the seal, and all the way to the adhesive track, you might be able to separate it from the inside... meaning the wire would be pulled inwards when cutting. To do this, however, you'll need to create two ways to thread the ends of the wire inwards.
Otherwise, remove all the interior panels and carefully cut them out from the inside using a knife.
Desperate times call for desperate measures.
It works best when the vehicle has been heated by the sun.
There are also vibrating cutting machines with angled blades. The problem with this method is that the blade can shatter if the adhesive layer is too thin in certain areas.
Translated on 12-07-2026, 9:34.
LZ
Post20-07-2015, 21:14    Subject: Rear side window modification for Audi C4 Avant? Quote
Are you talking about the outer trim piece? That is still available.
The Fein MultiMaster is the tool of choice; with its concave blade, the job is done in no time. Hold it from the outside or secure the disc icon_wink.gif.
Translated on 12-07-2026, 9:36.
No new posts DPF removal for Passat 3C with BMP engine Troubleshooting & Guides
No new posts Golf 3: Rear Door Corrosion - Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J documentary, low-frequency noise from rear brakes Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Risse in den hinteren Bremsscheiben beim A4 Avant Transmission, Chassis, Body & Interior
No new posts Problem beim Ausbau der ESP VP37 beim AEL-Motor (A6 2,5 TDI) Diesel Engine Technology
No new posts Audi A6 4F Avant Kombiinstrument, VAG-COM. On-Board Diagnostics (OBD)
No new posts Audi Avant 2.5 TDI: Power Loss Troubleshooting Diesel Engine Technology
