Kurbelwellenschraube der TDI Motoren | Posts 16+
Go to page: Previous  1, 2
Post24-08-2015, 7:57    Subject: Quote
Hi there.
I also bought a 3/4" impact wrench some time ago:
http://www.werkzeugatlas.de/schlagschrauber-3/4-toku-mi-20-p-673
Also, also: Important nuts in 3/4" size and a reducer to 1/2".
I wouldn't want to be without it now. The only important thing is to have the right hose; my 13mm hose just barely works, otherwise there isn't enough airflow.
Best regards, Rüdi.
Translated on 11-07-2026, 12:23.
haehnlein
Post24-08-2015, 9:47    Subject: Quote
TDI-GTI-4-Motion wrote:
because I'm not a fan of applying concentrated force to die-cast aluminum parts. } The part is made of solid steel. However, back then, the two 8.8 screws that are screwed into the KW sprocket bent. With 12.9 screws, it worked without any problems.
____________
Kein Auto mehr!
Translated on 11-07-2026, 12:24.
Post24-08-2015, 17:59    Subject: Quote
haehnlein wrote:
Das Teil ist aus massivem Stahl.
I wasn't talking about the bracket itself, but rather the edge where the KW flange meets the oil pan, which is where the part rests.
Translated on 11-07-2026, 12:25.
Post24-08-2015, 19:50    Subject: Quote
I found something else related to this:
Starting from that point, it would probably be advisable to relieve the load on the support points of the plate by using a longer lever arm for counteracting the force.
It's also best to avoid using an impact driver to loosen the screw.
Karma: +590 / -0   Thank you, like it!
Post24-08-2015, 20:33    Subject: Quote
Autoservice wrote:
Auf einen Schlagschrauber zum Lösen der Schraube sollte man ebenfalls verzichten.
That's what I wanted to know. Can you explain why?
So then, something like what I have here would be better:
Perhaps you could find an old crankshaft pulley, attach a long lever to it, and then apply force using the lever. In the picture I took, my body weight applied to the lever isn't enough to tighten the screw sufficiently.
PS: By the way, is it normal for an image to have been viewed almost 8000 times?
Translated on 11-07-2026, 12:27.
Post24-08-2015, 21:51    Subject: Quote
P.S.: By the way, is it normal that the image has been viewed almost 8000 times?
Zwischen dem, was man Menschen sagt was "angesagt" ist und dem, was tatsächlich angesagt ist, gibt es besonders in diesen Zeiten erhebliche Differenzen. icon_wink.gif
http://www.dieselschrauber.de/mediadaten.php
I like the idea with the old pulley wheel.
Translated on 11-07-2026, 12:28.
pax
Avatar-pax
2000 Volkswagen Passat
Post25-08-2015, 7:52    Subject: Quote
I'm glad that the torque specification for the ANY's KW bolt is only 120 Nm plus a quarter turn, and not 160 Nm plus half a turn like it was in the linked thread about the ACV.
Bye.
peace
Translated on 11-07-2026, 12:29.
Karma: +1344 / -0   Thank you, like it!
Post25-08-2015, 8:26    Subject: Quote
Das wollte ich wissen. Kannst Du es begründen?
Because the impact wrench forces the crankshaft axially into its bearings, which are the only things holding it in place.
christians
Post25-08-2015, 12:58    Subject: Quote
If your body weight isn't enough, you have to stand on the bar and rock it or jump. I do that with drive shafts too.
I can't imagine that would work the same way with a freely oscillating block.
Okay, so put the engine on the ground and attach something suitable to the engine mounts.
Gruß Christian
Translated on 11-07-2026, 12:30.
pax
Avatar-pax
Post26-08-2015, 15:02    Subject: Quote
The tool arrived today. The mounting bracket already came with standard 12.9 grade screws.
Bye.
peace
Translated on 11-07-2026, 12:31.
pax
Avatar-pax
dieselschrauber likes this.
Post20-09-2015, 17:14    Subject: Quote
It really just came down to the right approach and the right tools. With a 3/4" ratchet, a 1.2-meter long pipe, and the correct support, it went very smoothly even with the engine mounted on the crane.
The originally used counter-holder was actually a camshaft counter-holder, which could be screwed onto the crankshaft timing wheel, but it wasn't ideal. Since I had removed the timing belt, I couldn't rotate the engine to a useful position where the counter-holder would have been supported, and I was too afraid of accidentally over-revving the engine without the belt.
Next up will be the test on the built-in motor.
Bye.
peace
Translated on 11-07-2026, 12:32.
No new posts VTG Adjustment for VAG TDI Engines Technical Articles
No new posts DIY solution for starting engines with VP 37 Troubleshooting & Guides
No new posts VAG Engine Specs: Dimensions & Wear Limits Technical Data
No new posts Kurbelwellenschraube bei TDI 90 PS (ALH) Diesel Engine Technology
No new posts Crankshaft Screw TDI Diesel Engine Technology
No new posts Camshaft, 1st stage, last stroke Diesel Engine Technology
No new posts Crankshaft bolt torque specification ALH G4 Diesel Engine Technology
