chriskross Blaumann
Joined: 04/19/2006 Posts: 304 Karma: +3 / -0 Location: Österreich
01-10-2015, 20:16 Subject: DPF problem P2002 |
Hello! I'm having a problem with the DPF on my Crafter BJL 2.5 CR.
The DPF is not regenerating properly, please ignore the Lambda sensor error.
The DPF has already been replaced, as has the differential pressure sensor, and the adaptation process was also performed. However, 900 km later, another DPF error has appeared.
Regeneration cycle (starting at 40%) was completed with a tester, bringing it below 20%, after which the error could be cleared. After about 1 hour, it was working fine for 700 km, but now the DPF is clogged again.
Differential pressure in the LL: 20.4 mbar. When gas is applied: 150 mbar.
Temperature sensor at 85 degrees.
before the turbo, 270.
upstream of the DPF 210
after DPF 190
LL Ruhe regulation.
Cylinder 1: 0.21 mg
Cylinder 2, 0.42.
Cylinder 3 -0.54
Cylinder 4: 0.16
Zyl 5 -0.28
During the actuator test, the AGR valve functions correctly, but the throttle valve does NOT function during the actuator test with the ignition on. However, the engine stalls if it has been running and the throttle valve has been activated.
What else can I check? Does anyone have any ideas?
Address 91: Motor electronics Label file: 074-906-032.clb
Part number SW: 074 906 032 BA, Hardware: 074 906 032.
Component: R5 2.5L EDC 0400SG 5176
Revision: --H07--- Serial Number: VWZDZ0G1041
Encoding: 0003072
Operating number: WSC 65076 001 1048576
VCID: 52AF2AB1CDC0DDAEBB-8006
2 error codes found:
004374 - Bank 1, Probe 1; Heating circuit.
P1116 - 000 - Interruption.
Environmental conditions:
Speed: 0 RPM.
Torque: 195.2 Nm
Speed: 0.0 km/h
Last: 0.0%
Air mass/dose rate: 0.0 mg/H.
(no unit): 0.90
(no unit): 0.0
Binary value: 11001001
008194 - Particle filter, bank 1.
P2002 - 000 - Malfunction - Warning light ON.
Speed: 0 RPM.
Torque: 195.2 Nm
Speed: 0.0 km/h
(no unit): 3.0
Key press ratio: 14.6%
(no unit): 0.00
Temperature: 17.1°C
Time: 0.0 seconds. A6 AFB
A6 BRE DPF
Translated on 06-07-2026, 10:42.
Joined: 04/12/2002 Posts: 18086 Karma: +797 / -0 Location: St.Gallen 2018 Volkswagen T6
01-10-2015, 21:14 Subject: DPF problem P2002 |
Quote: | | The DPF is not regenerating properly, please ignore the Lambda error. |
and why, in your opinion, should one ignore the problem with the oxygen sensor?
Translated on 06-07-2026, 10:46.
Profile PM WWW Garage |
chriskross Blaumann
01-10-2015, 21:42 Subject: DPF problem P2002 |
Hello Rainer!
The oxygen sensor is disconnected because I removed the DPF again and then turned on the ignition. A6 AFB
A6 BRE DPF
Translated on 06-07-2026, 10:47.
01-10-2015, 21:49 Subject: DPF problem P2002 |
Okay, that's a valid argument.  Please check the temperatures measured by the sensors on the loader/DPF.
First, with the engine cooled down (it should be close to the ambient temperature), then at idle with the engine at operating temperature (wait about 30 seconds), and finally with full throttle and approximately 4000 rpm, under as much load as possible.
Roger Profi-Schrauber
Joined: 10/11/2002 Posts: 3035 Karma: +88 / -0 Location: Rodgau 2017 Volkswagen Golf Premium Support
05-10-2015, 15:39 Subject: Re: DPF Problem P2002 |
chriskross wrote: | | The throttle valve is NOT working during the actuator test with the ignition on, but the engine stalled after running and the valve was activated. |
Stay on that. According to the SSP (Service Information), for 4-cylinder CR engines, regeneration is definitely blocked in the event of a DPF failure (see SSP403, page 49, effect of failure J338)). I'm assuming that the implementation is similar for the 5-cylinder engines. Gruß
Translated on 06-07-2026, 10:49.
Profile PM Garage |
chli1976 Profi-Schrauber
05-10-2015, 16:19 Subject: Re: DPF Problem P2002 |
Roger wrote: |
Stay on that. According to the SSP (Service Information), for 4-cylinder CR engines, regeneration is definitely blocked in the event of a DPF failure (see SSP403, page 49, effect of failure J338)). I'm going to assume that it's implemented similarly in the 5-cylinder engines. |
Does it only regenerate if there's an error associated with it? VCDS
Translated on 06-07-2026, 10:50.
05-10-2015, 16:57 Subject: DPF problem P2002 |
I can't say for sure, but it's strange that it doesn't do anything during the actuator test. There is definitely a connection. Gruß
Translated on 06-07-2026, 10:51.
Profile PM Garage |
