Bremspedal weich, lässt sich durch drücken | Posts 16+
Go to page: Previous  1, 2
Karma: +1100 / -0   Thank you, like it!
Post24-08-2015, 7:29    Subject: Quote
"...and possibly corroded connector contacts on the sensors. The cables are also partially moved by the steering motion, which could cause this issue."
Translated on 13-08-2026, 3:13.
Karma: +645 / -0   Thank you, like it!
Post24-08-2015, 14:47    Subject: Quote
The connectors are actually placed inside the housing in a way that they are not energized.
Post24-08-2015, 17:29    Subject: Quote
What has happened to me 3-4 times this week is that when the steering wheel is fully turned, the ABS activates on the front right side, even though I have already released the brake pedal.
...or are those noises coming from the steering stop (wheel bearing housing and control arms)?
Translated on 13-08-2026, 3:14.
Httpbox
Post06-10-2015, 22:32    Subject: Quote
I've experienced that before too; the issue with the ABS while steering was caused by water in the sensor connector!
klahaui
Avatar-klahaui
2019 Volkswagen Golf
Post13-11-2015, 20:19    Subject: Quote
klahaui wrote:
I'm going to leave it as is; I've noticed the same thing in other vehicles this week.
Resolution regarding ABS (Anti-lock Braking System).
It never occurred to me before, but it only happens right after starting the car, when I'm reversing out of the driveway and immediately apply the brakes.
According to Volkswagen's documentation, the ABS enters a self-test mode a few seconds after starting the engine.
That's exactly where it happens: when I pull out of my driveway and brake just before reaching the road.
Translated on 13-08-2026, 3:16.
No new posts Doku A3 8L, Airbag STG error cannot be cleared Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Starter Cable Problems: Troubleshooting & Solutions Troubleshooting & Guides
No new posts Audi A3 8P: Floor Covering Detaching Problem Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Brake Pedal Stuck? Check Master Cylinder Now! Transmission, Chassis, Body & Interior
No new posts Can AFN be blocked? Diesel Engine Technology
No new posts Navigation CD cannot be ejected Electrical Systems, Vehicle Electronics, Multimedia
No new posts JMA: Better Performance at -13°C? Diesel Engine Technology
