Cylinder head cover leak AMF
New Topic Reply 🔗 ⭐ 🖹 Dieselschrauber - Index » Diesel Engine Technology
jarobaldu
Karma: +40 / -0   Thank you, like it!
Post08-10-2015, 8:27    Subject: Cylinder head cover leak AMF Quote
I'm having trouble with an oil leak on the valve cover.
I replaced the gasket (Elring), installed it dry, but it still leaked.
Then I applied sealant (Dirko Gray), but it's still leaking near the screws on the back.
Does anyone have a tip for me? Not enough packing material?
The hood itself has already been replaced with a used one.
Adrian.
 Undichte Zylinderkopfhaube (Spiegelbild)
 File size:  165.58 KB
 Viewed:  1952 times
AUDI A6 C4 1995 ABC/CRD
Fiat 124 Spider, Bj. 80
Post08-10-2015, 10:30    Subject: Cylinder head cover leak AMF Quote
Either the hood or the VDD is also defective, or there were errors during installation.
Normally, the sealant is only applied to the joints of the NW bearings.
Possibly, the leak is actually located somewhere else, and the oil then flows like a stream to the lowest point, where it drips off.
So... Remove the lid and take a look.
*Nichts ist einfacher, als sich schwierig auszudrĂŒcken......*
jarobaldu
Post14-10-2015, 8:55    Subject: Cylinder head cover leak AMF Quote
A few questions:
-Does anyone know why VW removed the gasket from the parts catalog?
- Is the sealant only needed in the corners?
- Put the dough into the bowl?
- Make the ZK (zinc anode) grease-free and do not apply any sealant there.
I've now ordered new gaskets with screws, for a new...
Adrian.
dieselschrauber likes this.
Post14-10-2015, 10:06    Subject: Cylinder head cover leak AMF Quote
Carefully examine the sealing groove of the hood to check if there is any crack or damage.
Post14-10-2015, 10:18    Subject: Cylinder head cover leak AMF Quote
jarobaldu wrote:
Does anyone know why VW removed the gasket from the parts catalog individually?
I'm experiencing a similar problem with my wife's 1.9 PD-TDI. The head gasket has already been replaced individually (as a separate part), but it is still leaking.
According to my mechanic, the plastic cover sometimes develops leaks because it can warp or crack. According to his statement, that's also the reason why VW generally replaces the entire hood instead of just the seal.
No idea if that's true. Due to a lack of time, I will now have everything completely replaced.
Greetings.
Guste.
jarobaldu
Post29-10-2015, 21:31    Subject: Cylinder head cover leak AMF Quote
That was already the second attempt with two used hoods, so I went to icon_biggrin.gif and bought new ones. I hope this will be leak-proof now.
But there's a new problem: the bleeder fitting has a different angle, and the bleeder hose could only be mounted under tension. Is it possible to rotate the fitting? I don't want to force it or try to make it work by any means necessary, otherwise those 122 euros will be gone very quickly...
old ZK hood: 045 103 469 C
New 045 103 469 G
Adrian.
P.S. The winnings arrived today icon_smile.gif Thank you!
 Zylinderkopfhaube AMF TDI
 File size:  1.72 MB
 Viewed:  853 times
Post29-10-2015, 21:47    Subject: Cylinder head cover leak AMF Quote
Can the sock be turned inside out?
I don't think so.
christo
Post29-10-2015, 23:00    Subject: Cylinder head cover leak AMF Quote
Certainly not.
Skoda Octavia III Combi (5E5), EZ: 6/2016, 2.0 TDI 110 kW (MKB: CRMB), 6-Gang-Schaltgetriebe (GKB: PGT)
Post29-10-2015, 23:02    Subject: Cylinder head cover leak AMF Quote
Alternatively, carefully heat the rigid plastic tube with a hot air gun; it will naturally take on a more relaxed shape. icon_idea.gif
jarobaldu
Post09-02-2016, 16:27    Subject: Cylinder head cover leak AMF Quote
I'd like to provide some feedback: The ZK hood was returned because the ventilation was incorrectly glued/welded.
After checking, I received a new one icon_smile_thumb_up.gif.
The new cooker hood design has different screws, the seal is thicker, and it is, above all, leak-proof icon_smile.gif.
Adrian.
Post09-02-2016, 16:31    Subject: Cylinder head cover leak AMF Quote
Thank you for your feedback! Do you happen to have the part number for the new cylinder head cover?
jarobaldu
Post10-02-2016, 15:07    Subject: Cylinder head cover leak AMF Quote
Here is the number: 045 103 469 G.
Adrian.
Post10-02-2016, 15:22    Subject: Cylinder head cover leak AMF Quote
No new posts Document A6 4B, Fog lights leaking Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts T6 Windshield Washer Fluid Leaking, Washer Fluid Tank Dam... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Passat 3B2 Achsmanschette undicht Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A3 2.0 CR-TDI CFFB cylinder head cover leaking? Diesel Engine Technology
No new posts 1.2L Polo 3-cylinder cylinder head cover Gasoline Engine Technology
No new posts Engine Oil on Injector Housing Diesel Engine Technology
No new posts VW Polo: Cylinder Head Torque Specs & Data Diesel Engine Technology
