Chain rattle in Audi A5 TFSI CJE (Solution)
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » General Tips
georgmech
Post16-02-2016, 15:06    Subject: Chain rattle in Audi A5 TFSI CJE Quote
Just got an Audi A5 TFSI CJE with a loud rattling noise coming from the front end.
Now, I have replaced the timing chain, including the tensioner, as well as the chain for the balance shafts. Once I had started the engine after that, it ran quietly, but after 5 minutes, the same problem occurred again.
I initially thought I had made a mistake, perhaps a tooth had been missed during assembly, or something similar. Now I have disassembled everything again, and I don't understand anything anymore.
Everything matches the markings, including the measurement, and fits perfectly. Could it be the camshaft adjusters?
Who can help us?
Thank you.
Wir sind eine Werkstatt in Langenrohr bei Tulln und kämpfen täglich mit Fahrzeugproblemen. Wir sind sehr dankbar das es dieses Forum gibt , denn man kann nicht alles wissen, aber man kann sein Wissen weitergeben am Ende haben alle was davon
Back to top Profile PM Email
Post16-02-2016, 20:50    Subject: Chain rattle in Audi A5 TFSI CJE Quote
How was the condition of the used parts? Is the oil pressure present, or is it sufficient?
Post16-02-2016, 21:26    Subject: Re: Rattling noises in Audi A5 TFSI CJE Quote
Very possible, I know of a few cases where this was the issue.
But first, as already mentioned, check the oil pressure (have it checked). icon_wink.gif
georgmech
Post17-02-2016, 10:33    Subject: Chain rattle in Audi A5 TFSI CJE Quote
The timing chain and tensioner don't really look worn out, I will check the oil pressure today, Thanks!
georgmech
Steffen W likes this.
Post22-02-2016, 14:48    Subject: Chain rattle in Audi A5 TFSI CJE Quote
Thank you for all the tips, the camshafts were defective, but they were replaced as a complete unit with the camshafts. The customer was very happy, but now it's running smoothly again.
Steffen W
Karma: +104 / -0   Thank you, like it!
Post23-02-2016, 6:35    Subject: Chain rattle in Audi A5 TFSI CJE Quote
Thank you for the feedback!
Passat Variant BGW 2005
Ratings - Chain rattle in Audi A5 TFSI CJE
No new posts Brake fluid change Audi A4 8K Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A3 Steering Wheel Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts _DEFINE0_ Ladelufttemperatur _DEFINE1_ am Audi A3 Technical Articles
No new posts TFSI ECU Diagnosis: Troubleshooting Guide On-Board Diagnostics (OBD)
No new posts Audi 80 RS2 Steering Wheel Controls: Same as Audi A4 B5? Transmission, Chassis, Body & Interior
No new posts FIS in the Audi Transmission, Chassis, Body & Interior
No new posts Audi A3 8P 1.9 TDI BLS: Parts & Info Diesel Engine Technology
