Golf V/Touran: Radio Unlock/Deactivate
New Topic Reply 🔗 ⭐ 🖹 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
K33ert4
Post20-03-2016, 21:21    Subject: Golf V/Touran: Radio Unlock/Deactivate Quote
I'm currently experiencing this problem with two cars:
Golf V GTI, Year: 2007.
Touran, Year: 2006
01304 - Radio
004 - No signal/communication - Intermittent.
Environmental conditions:
Error status: 00100100
Error priority: 2
Error frequency: 40.
Lost Count: 220
Mileage: 136,960 km
Time: 0.
Date: 2000.00.00
Time: 16:45:42
In both cars, the original radios were not installed at the time of purchase; instead, aftermarket radios were installed using CAN-bus adapters.
I replaced it with an Android radio.
What code do I need to write to fix this error?
If I disable the analog radio, I get an error message about incorrect coding.
01044 - Control unit incorrectly coded.
000 - - - Sporadically
Error status: 00100000
Error priority: 1
Error frequency: 1
Lost Count: 255
Mileage: 136,987 km
Time: 0.
Date: 2000.00.00
Time: 18:26:08
Best regards and thank you for your help.
I'm sorry, I can't translate that. It appears to be a random string of characters.
Translated on 24-10-2026, 14:57.
Post20-03-2016, 21:54    Subject: Golf V/Touran: Radio Unlock/Deactivate Quote
Normally, only remove it from the bill of materials (BOM) within the gateway.
Please provide the German text you would like me to translate into English. I will then provide the translation without any explanations.
I am unable to create a scan and upload it. I am a text-based AI and do not have the capability to interact with physical documents or upload files.
Translated on 24-10-2026, 15:00.
K33ert4
Post20-03-2016, 22:10    Subject: GTI Full Scan: Complete Inspection Guide Quote
Here's the scan of the GTI.
I will create and upload the Touran content tomorrow.
The error in the engine control unit was caused by user error and has already been resolved.
There's an issue with the comfort system due to a programming error made by the previous owner, and it's currently being resolved.
Sunday, March 20, 2016, 8:07:16 PM: 0.63495
VCDS -- A VAG/VAS emulator based on Windows, running on Windows 10 x64.
VCDS Version: DRV 15.7.4.1
Data as of: 20160223.
shop.dieselschrauber.org
Vehicle Identification Number: WVWZZZ1KZ8W017714
License Plate: BC-PS96
Mileage: 137,130 km. Repair order: Simma.
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die BĂ€ume, und die BlĂ€tter rascheln leise. Es ist ein wunderschöner Tag, um draußen zu sein."
Vehicle type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56
Mileage: 137,130 km
00-Steering angle sensor -- Status: OK 0000
01-Motor electronics -- Status: Error 0010.
03-Brake electronics -- Status: Error 0010.
08-Climate Control/Heating Unit -- Status: OK 0000
09-Central Electrical System -- Status: OK.
15-Airbag -- Status: OK 0000
16-Wheel steering electronics -- Status: Error 0010.
17-Terminal block insert -- Status: OK 0000
19-pin diagnostic interface -- Status: Error 0010.
Immobilizer system -- Status: OK 0000
42-Door Electric Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Comfort System -- Status: Error 0010.
52-door electric passenger side door - Status: OK 0000.
56-Radio -- Status: Error 1010.
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die BÀume, und die BlÀtter rascheln leise. Es ist ein wunderschöner Tag, um spazieren zu gehen oder ein Picknick im Park zu machen."
Address 01: Engine Control Unit
Label file: DRV\06F-907-115-AXX.clb
Part number SW: 1K0 907 115 Q, HW: 8P0 907 115 B.
Component: 2.0l R4/4V TFSI 0010
Revision: 5BH16--- Serial Number: VWX7Z0G43NM93M
Encoding: 0403000318070060
Operating number: WSC 00191 264 15243
VCID: 3460B30A57C3689EAA-8060
"One error found:"
000256 - Air mass sensor (G70)
P0100 - 004 - Power supply - Intermittent.
Error priority: 2
Error frequency: 1
Lost Count: 255
Mileage: 136,996 km
Time: 0.
Speed: 0 RPM.
Last: 0.0%
Speed: 0.0 km/h
Temperature: 31.0°C
Temperature: 20.0°C
Pressure: 950.0 mbar
Voltage: 12.446 V
Readiness: 0000 0000
Address 03: Brake Electronics Label file: DRV\1K0-907-379-MK60-F.lbl
Part number SW: 1K0 907 379 AC, HW: 1K0 907 379 AC.
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0004738
Operating number: WSC 01279 785 00200
VCID: 73E27016124D2FA673-8026
"One error found:"
01314 - Engine Control Unit.
013 - Please read the error memory - Intermittent.
Address 08: Climate Control/Heating. Label file: DRV\1K0-820-047.lbl
Part number SW: 1K0 820 047 FT Hardware: 1K0 820 047 FT
Component: Climatic PQ35 141 0909
Revision: 00141027 Serial Number: 00000000000000
Operating Number: WSC 00000 000 00000
VCID: 7BF258363A1D67E62B-802E
No error codes found.
Address 09: Central Electronics
Label file: DRV\3C0-937-049-23-H.lbl
Part number SW: 3C0 937 049 AE, Hardware number: 3C0 937 049 AE.
Component: On-board network system (SG) H52 2002.
Revision: 00H52000 Serial Number: 00000007149564
Encoding: ED050E2700041514471400001400000000197F070F0001
Operating number: WSC 12345 785 00200
VCID: 6CD06B6A4F73F05EB2-8038
Subsystem 1 - Part number: 1K1 955 119 E
Label file: DRV\1KX-955-119.CLB
Part: Wiper 270507 021 0501
Encoding: 00040853
Subsystem 2 - Part number: 1K0 955 559 AH
Label file: DRV\1K0-955-559-AG.CLB
Component: RLS 070508 054 0402
Encoding: 00209069
Address 15: Airbag
Label file: DRV\1K0-909-605.lbl
Part number SW: 1K0 909 605 T, HW: 1K0 909 605 T.
Part number: 37 AIRBAG VW8 020 2300.
Revision: 05020000 Serial Number: 0038PD18K5NK
Encoding: 0013111
Operating number: WSC 01269 785 00200
VCID: 3D76962E6489A9D655-8068
Subsystem 1 - Serial number: 6332MSME1A303E18B.
Subsystem 2 - Serial number: 6342MSME173C0D0FN
Subsystem 3 - Serial number: 6352QSME31170C5FL.
Subsystem 4 - Serial number: 6362QSME30314001X.
Address 16: Steering wheel electronics
Label file: DRV\1K0-953-549-MY8.lbl
Part number SW: 1K0 953 549 BC, Hardware: 1K0 953 549 BC.
Component: Steering column module 036 0070.
Encoding: 0000012
VCID: 74E0730A1743289E6A-8020
"One error found:"
00888 - Wiper switch for intermittent operation (E22)
014 - defective - intermittent.
Address 17: Control panel module
Label file: DRV\1K0-920-xxx-17.lbl
Part number SW: 1K6 920 864 Hardware number: 1K6 920 864
Component: COMBINATION INSTRUMENT VDD 1214
Revision: V0002000 Serial Number: VWX7Z0G43NM93M
Encoding: 0001103
Operating number: WSC 01725 111 52282
VCID: 6FEA7C667E650B4697-803A
Address 19: Diagnostic interface
Label file: DRV\1K0-907-530-V2.clb
Part number SW: 1K0 907 530 K, HW: 1K0 907 951.
Component: J533__Gateway H04 0021
Revision: H04 02 Serial number: 280507F2001341
Encoding: 3D0F034007000000
VCID: 2F6ABC66BEE54B46D7-807A
2 error codes found:
01304 - Radio
Error priority: 2
Lost Count: 220
Mileage: 136,960 km
Time: 0.
Date: 2000.00.00
Time: 16:45:42
Error priority: 1
Error frequency: 1
Lost Count: 255
Mileage: 136,987 km
Time: 0.
Date: 2000.00.00
Time: 18:26:08
Address 25: Immobilizer
Label file: DRV\1K0-920-xxx-25.clb
Component: IMMO VDD 1214
Operating number: WSC 26840 001 1048576
Address 42: Door electrical driver
Label file: DRV\1K0-959-701-MIN3.lbl
Part number SW: 1K0 959 701 M, HW: 1K0 959 701 M.
Component: Door Seal 006 1207
Coding: 0000052
VCID: 3878873A4BAB8CFE86-806C
Address 44: Steering Assist
Label file: DRV\1Kx-909-14x-44.clb
Part number: 1K1 909 144 M
Component: EPS_ZFLS, Size 074 H08, Part Number 1901.
Operating number: WSC 00000 028 00001
VCID: 35668E0E5CB971969D-8060
Address 46: Comfort System
Label file: DRV\1K0-959-433-MIN.clb
Part number: 1K0 959 433 AJ
Component: KSG 0401
Encoding: 00C802087F2D8405484A06F010CC
VCID: 78F8473A0B2B4CFE46-802C
Subsystem 1 - Component: Sounder, No Answer.
Subsystem 2 - Component: NGS, not mounted.
Subsystem 3 - Component: IRUE, not mounted.
"One error found:"
01134 - Alarm horn (H12)
004 - No signal/communication.
Address 52: Door electric, passenger side.
Label file: DRV\1K0-959-702-MIN3.lbl
Part number SW: 1K0 959 702 M, HW: 1K0 959 702 M.
Coding: 0000052
VCID: 397E823E70A195F679-806C
Address 56: Radio.
unavailable
End----------------------------(Duration: 01:16)-----------------------------
Translated on 24-10-2026, 15:23.
Post21-03-2016, 8:57    Subject: Golf V/Touran: Radio Unlock/Deactivate Quote
To be upfront: I'm not an expert on this topic, so I can only offer educated guesses.
I suspect that the CAN adapter or the aftermarket radio is responding to some CAN messages, but not all. This is likely the cause of the sporadic error entries. I have observed the same issue with an aftermarket parking sensor system.
Since individual messages are being addressed, even clearing the error codes doesn't resolve the issue. I'm simply living with the error memory entries, as they don't have any negative effects (and my idle current consumption is normal).
Greetings.
Sure, here's the translation:
"Guste" is a German word that means "gust" or "gust of wind." It can also be used to describe a sudden burst of something, such as laughter or anger.
Translated on 24-10-2026, 15:46.
K33ert4
Post21-03-2016, 13:21    Subject: VW Touran Log: Problems, Solutions & Tips Quote
Here's the log from the Touran...
Monday, March 21, 2016, 12:40:27:63495
VCDS Version: DRV 15.7.3.1
Data as of: 20160217
Vehicle Identification Number: WVGZZZ1TZ6W045405
License Plate: RV-OK1337
Mileage: 231,390 km. Repair order: Krassnik.
Vehicle type: 1T (1K0)
Scan: 01 03 08 09 15 16 17 18 19 25 42 44 46 52 56 62 72 76
Mileage: 231,390 km
01-Motor electronics -- Status: OK 0000
03-Brake electronics -- Status: OK 0000
08-Climate/Heating Unit -- Status: OK 0000
09-Main Electrical System -- Status: OK.
16-Wheel Steering Electronics -- Status: OK 0000
18-Heater -- Status: Error 0010.
42-Door Electric Driver -- Status: Error 0010.
44-Steering assist -- Status: OK 0000
46-Comfort System -- Status: OK 0000
52-door electric passenger door - Status: OK 0000.
62- Door, electric, left and right -- Status: OK 0000
72-Door, electric, high, right side -- Status: OK 0000.
76-Parking assist -- Status: OK 0000
Address 01: Engine Control Module
Label file: DRV\03G-906-016-BKD.lbl
Part number SW: 03G 906 016 BQ, HW: 028 101 190 6.
Part: R4 2.0L EDC G000SG 6254
Revision: 12345678 Serial number: VWZ7Z0E2470554
Encoding: 0000072
Operating number: WSC 01324 785 00200
VCID: 73E27016124D2FA67D-8026
Readiness: 0 0 0 0 0
Part number SW: 1K0 907 379 Q HW: 1K0 907 379 Q
Component: ESP FRONT MK60 0102
Revision: 00T12001
Encoding: 0023238
VCID: 4088EFDA137BC43E30-8014
Address 08: Climate Control Module. Label file: DRV\1K0-907-044.lbl
Part number: 1K0 907 044 BC
Component: Climatronic PQ35 066 0606
VCID: 69DE127E4081E576C7-803C
Part number SW: 3C0 937 049 E, HW: 3C0 937 049 E.
Component: On-board network module H37 1002.
Revision: 00H37000 Serial Number: 00000005061367
Encoding: 218B8F210104100A00120C000000000000097F075C
Operating number: WSC 12345 123 12345
VCID: 2B52A8768AFD3766F5-807E
Subsystem 1 - Part number: 1T0 955 119 C
Part: Wiper VW358 012 0401.
Encoding: 00065493
Address 15: Airbag
Label file: DRV\1T0-909-605.lbl
Part number SW: 1T0 909 605 C. Hardware: 1T0 909 605 C.
Part number: 02 AIRBAG VW62 0506 1500.
Revision: 09025000 Serial Number: 0038BD0ER2C4
Encoding: 0012338
VCID: 35668E0E5CB9719693-8060
Part number SW: 1K0 953 549 AF, HW: 1K0 953 549 AF.
Component: Steering column module 634 0070.
Encoding: 0000042
VCID: 76E44902013F3A8E5A-8022
Part number: 1T0 920 872 A
Component: COMBINATION INSTRUMENT VDD 1212
Encoding: 0005101
VCID: 326CB512ADD766AEB6-8066
Address 18: Auxiliary heater
Label file: DRV\1K0-815-007.clb
Part number: 1K0 815 007 AP
Component: Portable heater 020 3602
Revision: 00020000 Serial Number: 09011559000000
Encoding: 0001112
VCID: 72EC75126D5726AE76-8026
3 error codes found:
01406 - No flame formation.
Error priority: 0
Error frequency: 118.
Lost Count: 176
Mileage: 228,081 km
Time: 0.
Date: 2000.00.00
Time: 30:58:58
Start
Temperature: 53.0°C
Temperature: 49.0°C
02251 - Heating device locked.
000 - -
Error status: 01100000
Error priority: 0
Error frequency: 1
Lost Count: 136
Mileage: 228,084 km
Time: 0.
Date: 2000.00.00
Time: 15:00:30
00664 - Fuel level indicator.
002 - Lower limit exceeded - Intermittent.
Error status: 00100010
Error priority: 0
Error frequency: 3.
Lost Count: 140
Mileage: 227,046 km
Time: 0.
Date: 2000.00.00
Time: 16:19:34
Label file: DRV\1K0-907-530-V1.clb
Part number SW: 1K0 907 530 F, HW: 1K0 907 951.
Component: Gateway H10 0120
Revision: H10 Serial Number: 28001057220A63
Encoding: 3D3F1740078002
VCID: 2A5CAD7285072E6E0E-807E
"One error found:"
01304 - Radio
Error priority: 2
Error frequency: 254
Lost Count: 19
Mileage: 229914 km
Time: 0.
Date: 2000.00.00
Time: 15:58:19
Component: IMMO VDD 1212
Address 42: Door electric, driver.
Label file: DRV\1K0-959-701-MIN1.lbl
Part number: 1K0 959 701 B
Component: Door control unit 08 0015.
Encoding: 0000116
VCID: 2D56A66EB4E93956EB-8078
01331 - Door control unit, driver's side (J386)
014 - defective
00932 - Power window motor, driver's side (V147)
005 - No or incorrect initial setup/adaptation - Intermittent.
Part number: 1K1 909 144 J
Component: EPS_ZFLS, Size 5, D04 1606.
Label file: DRV\1K0-959-433-MAX.clb
Part number SW: 1K0 959 433 AR Hardware number: 1K0 959 433 AR
Component: 01 KSG PQ35 G2 010 0101
Revision: 00010000 Serial Number: 00000000000000
Encoding: 009002085103087F2D06840560084F01E0A500
VCID: 00082FDA53FB043E70-8054
Subsystem 1 - Component: Sounder (not mounted)
Address 52: Door electronics, passenger side.
Label file: DRV\1K0-959-702-MIN2.lbl
Part number: 1T0 959 702 B
Component: Door seal 024 2301
Coding: 0000244
VCID: 377A840646B5838681-8062
Address 56: Radio.
unavailable
Address 62: Door electric, left/right.
Label file: DRV\1K0-959-703-GEN1.lbl
Part number: 1K0 959 703 B
Component: Door control unit 06 0214.
Encoding: 0000048
VCID: 2F6ABC66BEE54B46D9-807A
Address 72: Door electric strike, high, right.
Label file: DRV\1K0-959-704-GEN1.lbl
Part number: 1K0 959 704 B
Encoding: 0000048
VCID: 3068BF1AA3DB54BEC0-8064
Address 76: Parking Assist
Label file: DRV\1K0-919-283.lbl
Part number: 1K0 919 283 A
Component: 02 Parking Assist System 0101
End----------------------------(Duration: 01:43)-----------------------------
Translated on 24-10-2026, 16:13.
No new posts Golf 5 Radio Volume Problem - Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A2 Radio: Won't Turn On After Parking? (8Z0) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A3 Radio Problem: Fix for 8L Models Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf VII: Disable Pace Car Lights (Coding) On-Board Diagnostics (OBD)
No new posts Golf 5 Radio Coding: How-To Guide Electrical Systems, Vehicle Electronics, Multimedia
No new posts Golf 3: Wiring Harness for Car Radio Installation Transmission, Chassis, Body & Interior
No new posts Skoda Radio Symphony in Golf 3 Electrical Systems, Vehicle Electronics, Multimedia
