georgmech Schrauber
Joined: 09/10/2009 Posts: 69 Karma: +8 / -0 Location: Langenrohr
21-01-2016, 16:28 Subject: VW T5 CAA Driveshaft Spins in 7-Speed DSG Transmission |
The right driveshaft is spinning inside the transmission, but there are no more splines on the transmission shaft. Are there any replacement parts available for this? Wir sind eine Werkstatt in Langenrohr bei Tulln und kämpfen täglich mit Fahrzeugproblemen. Wir sind sehr dankbar das es dieses Forum gibt , denn man kann nicht alles wissen, aber man kann sein Wissen weitergeben am Ende haben alle was davon
Translated on 10-09-2026, 18:16.
Profile PM Email |
21-01-2016, 18:35 Subject: VW T5 CAA Driveshaft Spins in 7-Speed DSG Transmission |
I've moved it to the appropriate section.
Unfortunately, a new differential will be needed. GKB? MfG. Michael
Translated on 10-09-2026, 18:17.
Profile PM Garage |
Joined: 04/12/2002 Posts: 18095 Karma: +799 / -0 Location: St.Gallen 2018 Volkswagen T6
21-01-2016, 18:47 Subject: VW T5 CAA Driveshaft Spins in 7-Speed DSG Transmission |
I would also like to know the mileage and the primary purpose for which the vehicle was used.
Profile PM WWW Garage |
georgmech Schrauber
25-01-2016, 15:37 Subject: Short Distance Applications |
The vehicle was an ambulance and, of course, was driven at full speed. It has a mileage of 280,000 km. After cleaning it, I'm now not so sure that the driveshaft spun out, although the ridges in the transmission look quite damaged. According to the previous owner, the car stopped without any unusual noises and couldn't be driven away. However, there was only 1 liter of transmission oil in it, although it's not known if the rest was drained. Currently, I've only removed the clutch discs, and they look like new. They don't smell, and the steel friction discs are neither blue nor warped. Wir sind eine Werkstatt in Langenrohr bei Tulln und kämpfen täglich mit Fahrzeugproblemen. Wir sind sehr dankbar das es dieses Forum gibt , denn man kann nicht alles wissen, aber man kann sein Wissen weitergeben am Ende haben alle was davon
Translated on 10-09-2026, 18:18.
Profile PM Email |
25-01-2016, 15:44 Subject: VW T5 CAA Driveshaft Spins in 7-Speed DSG Transmission |
Thanks, it sounds like the DSG didn't perform too badly after all...
Translated on 10-09-2026, 18:19.
georgmech Schrauber
26-01-2016, 10:18 Subject: VW T5 CAA Driveshaft Spins in 7-Speed DSG Transmission |
"Does anyone know where I can find a refurbished or used one? But what bothers me personally is that the car simply wouldn't drive anymore without making any strange noises, meaning you can rule out gear damage or something similar. Are there any common issues I can look out for? Like a faulty control unit or something?" Wir sind eine Werkstatt in Langenrohr bei Tulln und kämpfen täglich mit Fahrzeugproblemen. Wir sind sehr dankbar das es dieses Forum gibt , denn man kann nicht alles wissen, aber man kann sein Wissen weitergeben am Ende haben alle was davon
Profile PM Email |
26-01-2016, 12:13 Subject: VW T5 CAA Driveshaft Spins in 7-Speed DSG Transmission |
georgmech wrote: | | But there was only 1 liter of transmission oil inside... |
He actually can't drive with that.  MfG. Michael
Translated on 10-09-2026, 18:20.
Profile PM Garage |
Mc_Givertechnik Schrauber
Joined: 02/27/2003 Posts: 390 Karma: +3 / -0 Location: Graz Österreich 2010 Volkswagen T5 Premium Support
18-04-2016, 8:10 Subject: VW T5 CAA Driveshaft Spins in 7-Speed DSG Transmission |
Hello!
Considering that the right driveshaft has always been a weak point and still is, it's truly remarkable how long it lasted.
Whether it's a manual or automatic transmission, the trapezoidal teeth in the area where the driveshaft connects to the transmission tend to wear out. It's recommended to check this area for play whenever possible, whether during a service or simply when working under the car. This can often help prevent larger damage, as in this case.
"Is there any information from the previous owner or records of the repairs that have been carried out? Is this the original transmission? Is this the original right-hand half-shaft? Based on the mileage and the usage profile, I would be very surprised if all of these parts are still from the factory."
Greetings,
Peter. VW T5 GP Multivan Startline CAAC 2,0 CRD 103 KW, Audi A2 1,4 16V AUA 2001, Audi A2 1,4 16V AUA 2003;Renault Zoe PHII 135 2020;
Translated on 10-09-2026, 18:21.
Profile PM Email Garage |
