Turn AGR on or off via switch
SeatLeon
Post04-10-2003, 12:19    Subject: Turn AGR on or off via switch Quote
'If you unplug the connector from the EGR control valve, it will generate an error code, but the EGR system will be deactivated. Is it possible to trick the control unit by sending a false feedback signal while the connector is unplugged, thereby preventing the error code from appearing? If this works, you could install a small switch inside the car to enable or disable the EGR system.' Has anyone ever tried that before?
Translated on 07-07-2026, 2:42.
ideeAlist
Post04-10-2003, 12:58    Subject: Turn AGR on or off via switch Quote
Yes, that should be possible. You only need an electrical dummy that has similar properties to the solenoid coil of the pneumatic valve for the EGR control air.
So, take an ohmmeter and measure the ohmic resistance of the coil. Then, install a resistor with a power rating of 3 watts, and connect it in series with the circuit, using a switch to connect it in place of the solenoid coil.
A potential issue could be the moment of switching, where the connection is open for an extremely short period. I'm not sure if the control unit flags an error in that situation. Or you only switch it on when the ignition is off.
Translated on 07-07-2026, 2:43.
Post04-10-2003, 17:00    Subject: Turn AGR on or off via switch Quote
Based on my experiments with the AFN, the EDC is very tolerant to the valve's resistance value.
It normally measures around 20 ohms, but my EDC device accepts resistors up to the kOhm range without reporting any errors.
If you're experiencing the same issue, I would suggest connecting a resistor of a corresponding high value in parallel with the valve, and inserting a normally open switch between the resistor and the valve.
For example, with a 2.2 kOhm resistor, a power rating of 1/10 Watt is more than sufficient.
When the switch is open, the EDC still sees the resistor as a valve dummy and doesn't complain (at least) about the resistor icon_wink.gif.
Translated on 07-07-2026, 2:45.
Achim
Post06-10-2003, 8:01    Subject: Turn AGR on or off via switch Quote
@ulf yes, that's how it works.
But the error entry in the control unit doesn't really have any effect, does it? Then that would be about...
Is the resistance of a coil dummy just cosmetic, or am I mistaken?
Translated on 07-07-2026, 2:46.
Post06-10-2003, 16:12    Subject: Turn AGR on or off via switch Quote
Achim wrote:
@ulf yes, that's how it's done.
Resistance as a coil dummy is just cosmetic, or am I wrong?
Hi Achim,
Cosmetic fixes to keep the error log clear - that's probably true.
However, I haven't driven it yet with the valve plug removed, so I can't completely rule out a limp-home mode-like reaction.
Translated on 07-07-2026, 2:47.
PrivatBereich
Post06-10-2003, 18:15    Subject: Turn AGR on or off via switch Quote
However, I haven't driven the vehicle yet with the valve plug removed, so I cannot completely rule out a limp-home mode-like reaction.
My G3, engine code AHU, has been running with the connector unplugged for a while. I haven't noticed any behavior similar to a limp-home mode. Whether this applies to all small and medium-sized enterprises (SMEs) is not certain, but it is very likely to apply to the older ones.
-Private
Translated on 07-07-2026, 2:48.
Achim
Post07-10-2003, 7:33    Subject: Turn AGR on or off via switch Quote
I once tried using a switch and a 1k, 1/4-watt resistor. I am.
I never thought of connecting the resistor in parallel with the inductor, and then...
simply turning off the coil icon_redface.gif Sometimes you just end up twiddling your thumbs.
At the time of the switchover, there was, of course, an interruption.
A fault entry in the control unit did not affect the driving characteristics in my case.
Translated on 07-07-2026, 2:49.
No new posts T4 2,5 ACV Ignition Lock or MSTG General Tips
No new posts Kostenvergleich: Diesel oder Benziner? Technical Articles
No new posts Passat 3C oder Superb 3T Notentriegelung Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Electrical. Hidden operation - button or switch? Transmission, Chassis, Body & Interior
No new posts ESP ausschalten Diesel Engine Technology
No new posts Zuheizer ausschalten On-Board Diagnostics (OBD)
No new posts Ablendlicht ausschalten ? Transmission, Chassis, Body & Interior
