Probleme nach Einbau Gaspoti vom Golf IV am 1Z | Posts 16+
Go to page: Previous  1, 2
nobu
2018 Volkswagen Tiguan
Post29-05-2016, 18:13    Subject: Quote
Okay, I've given up;-(
After several unsuccessful attempts and measurement series, I'm now reinstalling the original potentiometer for the GOLF III and will build a waterproof box underneath the car.
The reason I switched to a GOLF V was because the potentiometer was moved inside the car. In my GOLF III, the potentiometer would get flooded after every time I drove through water, and then it would become defective.
If what you're saying about "1 Volt" is correct, then I don't understand the behavior.
I connected 10 kΩ resistors in series. The result was an idle rate of 10-12%, compared to the previous 8-9%.
Then I had a 10 kΩ resistor connected in parallel with the internal input impedance. This resulted in the system only delivering 80% of its power at full throttle. Nothing has changed regarding the idle speed.
Check. And that's the end of the tests.
Käfer Cabrio
Amarok Single Cab Bimobil (seit September 2016)
Tiguan II, 190 PS EZ.: 06.2018
Mercedes E350 Cabrio
Wiesel
Post29-05-2016, 22:13    Subject: Quote
Thank you for the feedback... unfortunately, I only just saw this thread.
Two ways immediately come to mind as to how this was likely made possible icon_sad.gif.
- Modify the fuel injection map in the engine control unit (ECU) to match the new requirements.
- Adaptive adjustment using an operational amplifier.
If you happen to revive the topic - please send me a private message. icon_wink.gif
dieter
Karma: +13 / -0   Thank you, like it!
dieselschrauber likes this.
Post31-05-2016, 16:07    Subject: Quote
I installed the gas cable from the T3 under the driver's seat and shortened it accordingly.
and it has a Golf 3 with a gas engine.
This helps keep the potentiometer dry and preserves the bus pedal assembly.
Dieter.
T3 syncro 16 AFN
No new posts Cruise Control Installation Problems Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 5 Problems: Tailgate/Rear Door Issues Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 4 Motion, Year 2013, Problems with ASR/ESP/ABS/Autohold Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Golf 3: DWA Installation Problems & Guide Diesel Engine Technology
No new posts GRA Installation Problems On-Board Diagnostics (OBD)
No new posts GRA Installation Error: Troubleshooting Guide Diesel Engine Technology
No new posts ACC Coding for A4 B8 FL After AHK Installation On-Board Diagnostics (OBD)
