Steering Angle Sensor VW Polo 9N
Basti1605
Post07-07-2016, 16:22    Subject: Steering Angle Sensor VW Polo 9N Quote
Hello everyone,
I have a Polo 9N with a fault code: 00778 - Steering angle sensor (G85) - 49-00 - No communication.
I wanted to check the sensor in the module control unit (MCU) to see if it was working. However, I didn't really manage to navigate the blocks. This is completely new territory for me. Do you go through each individual MCU block until you reach the "target," or do you already know most of them? Is there any literature I can study? Nevertheless, I was eventually able to locate the sensor, but the value in the block didn't change when the steering wheel was turned.
The steering works perfectly, and there are no warning lights illuminated.
What else can I do here?
Greetings, Basti.
Log-WVWZZZ9NZ6D069970-185280km.txt
 File name:  Log-WVWZZZ9NZ6D069970-185280km.txt
 File size:  4.36 KB
 Downloaded:  772 times
VCDS Support im Raum Hannover & Hildesheim
Translated on 31-08-2026, 12:36.
Post11-07-2016, 21:09    Subject: Steering Angle Sensor VW Polo 9N Quote
Hi.
2 error codes found:
01598 - Voltage of traction battery.
07-10 - Signal too weak - Sporadic.
Was ist mit the steering wheel? It's possible that the errors are also a result of undervoltage (a defective or discharged vehicle battery).
Make sure the on-board voltage is correct, then clear the error codes and see what happens. You can find the steering angle in the measurement blocks of the ABS/ESP system.
Translated on 31-08-2026, 12:38.
No new posts Steering Angle Sensor: How to Recalibrate? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Polo 86c 40 kW, year 1992, 1272 ccm, AAV throttle potenti... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts WIV reset on VW Polo 9N TDI Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A3 8P Steering Angle Sensor G85 Electrical Systems, Vehicle Electronics, Multimedia
No new posts Calibrate steering angle sensor G85 Electrical Systems, Vehicle Electronics, Multimedia
No new posts Steering Angle Sensor Calibration Issues On-Board Diagnostics (OBD)
No new posts Steering Angle Sensor Golf 4: Location & Installation On-Board Diagnostics (OBD)
