Golf 4 Rear Window Problems & Fixes
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
Post19-08-2016, 10:16    Subject: Golf 4 Rear Window Problems & Fixes Quote
Friends recently bought a used G4 "Generation" from the early 2000s (engine: 1.4L APE) with 113,000 km on the odometer. It's their first car with features like central locking and electric windows, which has opened the door for them to experience the world of quirky comfort electronics.
Excerpt from the error scan:
Code:
Adresse 46: Komfortsystem        Labeldatei: DRV\1J0-959-799.lbl
   Teilenummer: 1J0 959 799 AH
   Bauteil: 4E Zentral-SG Komf. 0001
   Codierung: 04097
   Betriebsnr.: WSC 31414
   VCID: 040C5AA414E7E26286-4B00
   Subsystem 1 - Teilenummer: 1J1959801C
   Bauteil: 4E Tõrsteuerger. FS0002r
   Subsystem 2 - Teilenummer: 1J1959802D
   Bauteil: 4E Tõrsteuerger. BF0002r
   Subsystem 3 - Teilenummer: 1J4959811C
   Bauteil: 4E Tõrsteuerger. HL0002r
   Subsystem 4 - Teilenummer: 1J4959812C
   Bauteil: 4E Tõrsteuerger. HR0002r
2 Fehlercodes gefunden:
00914 - Schalter für Fensterheber hinten links; Fahrer (E53)
            27-10 - unplausibles Signal - Sporadisch
00915 - Schalter für Fensterheber hinten rechts; Fahrer (E55)
Correspondingly, the rear door handles only respond to switch commands from the driver's door at random. The direct operation from the back seat functions normally.
According to the SLP (System Logical Plan), the signals from the two rear door switches are transmitted via an analog cable to the driver door control unit (StG), and from there, via CAN bus, to the other door control units and the central comfort control unit.
All four driver's side door control module (DOOR CM) switches connect the respective "sensor wire" to a common ground line through variable resistors. The DOOR CM likely detects which command is being given based on the current flowing to ground through these resistors.
Based on all of this, I suspect that the current flow from both rear door switch sensors is no longer reliably within the specified range for command recognition by the door control unit; possibly due to infrequent use and subsequent corrosion of the switch contacts.
Are there any other common causes known for the aforementioned error? I would currently tend to rule out waterlogged A-pillar connectors, because the driver commands to all three other power windows are transmitted via CAN bus, only the two rear power windows are affected, and no CAN errors have been logged.
Translated on 25-07-2026, 5:51.
Gremlin
Avatar-Gremlin
Karma: +92 / -0   Thank you, like it!
2000 Audi A4 Avant Consumption
dieselschrauber likes this.
Post14-09-2016, 10:08    Subject: Golf 4 Rear Window Problems & Fixes Quote
Hi Ulf,
I would try to fix it.
We actually have something there icon_idea.gif.
Okay, I'm ready. Please provide the German text you want me to translate into English.
Translated on 25-07-2026, 5:54.
Post14-09-2016, 19:14    Subject: Golf 4 Rear Window Problems & Fixes Quote
Thank you @ Gremlin icon_biggrin.gif.
I'll send the PDF to my friends right away.
Translated on 25-07-2026, 5:55.
No new posts Golf 3: Rear Door Corrosion - Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J documentary, low-frequency noise from rear brakes Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat 2000: Rear Brake Noise Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A3 Rear Brakes: Common Problems & Solutions Transmission, Chassis, Body & Interior
No new posts Rear Door Problems: Sensor Not Detecting Opening On-Board Diagnostics (OBD)
No new posts VW 1J 4Motion: Rear Spring Replacement Transmission, Chassis, Body & Interior
No new posts Central Locking: Rear Doors Won't Open? Electrical Systems, Vehicle Electronics, Multimedia
