P2563 Passat CC: Diagnose & Lösungen (2.0 TDI)
New Topic 🔒 Locked 🔗 ⭐ 🖨 Dieselschrauber - Index » Diesel Engine Technology
blackeyes71
Post14-01-2017, 5:51    Subject: P2563 Passat CC: Diagnose & Lösungen (2.0 TDI) Quote
"I need help. For a few days now, the engine warning light has been on, and the ignition coil is flashing (see photo). I had the error codes read, and it says: 'Turbocharger wastegate control solenoid position sensor circuit; Range/Performance'."
-Permanent!!! It actually runs normally, but it has gone into emergency mode a few times. What could be the problem?
Thank you in advance.
 Mit Vollgas gemessen
 File size:  3.81 MB
 Viewed:  5464 times
 File size:  4.63 MB
 Viewed:  4796 times
 File size:  5.24 MB
 Viewed:  9730 times
Translated on 09-09-2026, 2:54.
FloFrtdi likes this.
Post14-01-2017, 10:51    Subject: P2563 Passat CC: Diagnose & Lösungen (2.0 TDI) Quote
Turbocharger - Capacity not sufficient
"So, the ignition coil is blinking... You wrote above that the engine is a 2.0 TDI, how can an ignition coil be blinking? This is a diesel engine, and that component is called a glow plug."
Do you realize the nonsense you are writing and that is displayed in your "diagnosis program"? Do you even notice it anymore? icon_confused.gif
Furthermore: Please note the rules for problem-solving and posting. This post is in the wrong section and will therefore be closed and moved.
To troubleshoot issues, a vehicle diagnostic tool is required. We offer support for our KOBD2Check diagnostic systems and VCDS. Please refer to the terms of service.
KOBD2Check would have displayed a reasonable error message (low boost pressure), and you would have received help here as well.
@blackeyes71Viewing profile: blackeyes71: You should actually be thanked for this post, as it shows what competing products to KOBD2Check offer...
 KOBD2Check, Beispiel für andere Fehlercodes.
dieselschrauber.de Support Zugang mit Fehlerdatenbank (Info zu Fehlercodes wie z.B. P0420 oder P2100 direkt per Klick im Fehlerspeicher).
Experten helfen bei der Lösung des Problems und unterstützen Sie bei Fehlersuche und Fehlerbehebung.
 File size:  93.12 KB
 Viewed:  4031 times
Translated on 09-09-2026, 2:56.
No new posts P2563 Error: Turbocharger Overboost Fault (CR-TDI) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P2563 - Positionsgeber für Ladedrucksteller: unplaus. Si... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Error code P1351 General Tips
This topic is locked, you cannot edit or reply. EPB Problem: Passat 3C, 2009 Model Transmission, Chassis, Body & Interior
No new posts Passat 2009 power loss Diesel Engine Technology
No new posts Replacement MFL (multifunction leather steering wheel) wi... Electrical Systems, Vehicle Electronics, Multimedia
No new posts Intermittent immobilizer problem, Passat 3C Variant, 2009 On-Board Diagnostics (OBD)
