A4 Cabrio 2.5TDI BDG: grauer Rauch bei Kaltstart | Posts 64+
Go to page: Previous  1, 2, 3, 4, 5
Tagessuppe
Karma: +36 / -0   Thank you, like it!
2001 Audi A2 Consumption
Post14-12-2016, 12:00    Subject: Quote
I'd also like to suggest the possibility that the glow plugs might be too short. I experienced this with my A2 3L. While it still started reasonably well in the winter, the additional glow plugs were already defective after about 150,000 km, but the noise was excruciating. The glow plugs were about 1.5 cm too short. So, even when they were still functioning, they probably had little effect on the starting process.
My Allroad 2.5 TDI AKE, on the other hand, started very reluctantly, even with only 2 functioning glow plugs. It was similar to what's shown in the video, except that in my case, the 2 cylinders with the good glow plugs ran perfectly, while the other cylinders that were reluctant to ignite took some time to actually fire.
Translated on 11-09-2026, 21:21.
Florian320
2004 Audi Cabriolet
Post16-01-2017, 17:33    Subject: Quote
Okay, so the car was just at the Bosch service center, which is (almost) around the corner.
There, my request to expand and inspect the combustion chamber was fulfilled, and during the inspection of cylinder four, a glow plug was found to be quite heavily coated with soot.
Whether dirt was present at the sealing point during installation, or whether the spark plug simply wasn't tightened correctly, no one knows for sure.
I now just have to wait until the engine is completely cold, and then I will report back.
 Glühkerze mit beeindruckend verrußtem Schacht, etwa 13000km alt
 File size:  994.56 KB
 Viewed:  464 times
Translated on 11-09-2026, 21:22.
Post16-01-2017, 18:30    Subject: Quote
Does the length or glow plug type fit?
Translated on 11-09-2026, 21:23.
Florian320
2004 Audi Cabriolet
Post16-01-2017, 18:34    Subject: Quote
Yes, they are correct, according to the Bosch service center. The model that is now installed, which was also used by Audi about a year ago, is the Beru GN008.
Post16-01-2017, 19:44    Subject: Quote
dieselschrauber wrote:
Another possibility would be a coolant temperature sensor that only provides incorrect readings in cold temperatures; I've experienced that before.
Right now, it's beautifully cold. Check the coolant temperature that the engine control unit (ECU) sees when the engine is cold, and compare it to the outside temperature.
Translated on 11-09-2026, 21:24.
Florian320
2004 Audi Cabriolet
Post16-01-2017, 20:15    Subject: Quote
Unfortunately, I won't be able to get the car started today because I need it to get to work. However, it should work eventually, as I checked the temperature and it was already showing 1.X degrees even when the outside temperature was around -2 degrees.
Post16-01-2017, 21:28    Subject: Quote
Just to be sure: Has the car been modified? If an artist captured the wrong license plate number... icon_cool.gif
Translated on 11-09-2026, 21:25.
Florian320
2004 Audi Cabriolet
Post16-01-2017, 21:38    Subject: Quote
No, absolutely nothing has been changed on that car, it's really quite conventional icon_smile.gif.
Florian320
2004 Audi Cabriolet
dieselschrauber likes this.
Post21-01-2017, 16:38    Subject: Quote
Okay, I have good news: it was the spark plug that was causing the problem.
This morning, I started the car that was parked outside in the -4°C (25°F) temperature, and the engine started right up and sounded as it should.
There was absolutely no smoke produced.
So, it turned out that the glow plug wasn't properly seated.
So: the case is solved, thank you for your help!
Translated on 11-09-2026, 21:26.
Post21-01-2017, 16:42    Subject: Quote
Thank you for your feedback!
No new posts Audi A4 B7/8E 1.8T BFB - Shaking/Vibration after cold start Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Golf 1J, from week 48/98, Clattering noise afte... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Oil warning light after cold start, all models ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Fuel gauge not working - A4 Cabrio 2.5TDI (BDG) Diesel Engine Technology
No new posts White smoke after cold start Diesel Engine Technology
No new posts Cold start is fine, but after a few minutes there's blue ... Diesel Engine Technology
No new posts Oil Sludge in ARL Coolant: Causes & Fixes Diesel Engine Technology
