WarLord Guest
14-10-2003, 19:57 Subject: CAN Bus Climatronic: Which Models Have It? |
'Can anyone please provide me with part numbers for VW Climatronics? Or are the Climatronics (including the newer ones) not yet connected to the CAN bus, or do they not require it for full functionality? I want to install a Climatronic from a Golf IV, Passat 3B, etc. into a 35i 3A5 B4, which, as you know, does not have a CAN bus.'
Best regards, WarLord.
Translated on 09-10-2026, 17:10.
Julian Guest
15-10-2003, 8:08 Subject: CAN Bus Climatronic: Which Models Have It? |
In the Golf 4, all components are connected to the CAN bus via the instrument cluster. Therefore, you also need to install a compatible instrument cluster, otherwise you will miss important signals, such as the mileage data.
In Climas >5/99, the connection to the MSG (Message System Gateway) has also been implemented. This Clima then has up to 70 service channels, instead of 44.
Translated on 09-10-2026, 17:11.
Gremlin Guest
15-10-2003, 11:47 Subject: CAN Bus Climatronic: Which Models Have It? |
In my G4 plans, the Climatronic system does not use CAN (Controller Area Network) communication.
Extra wiring for motor, transmission, and combination unit.
CU Gremlin.
Translated on 09-10-2026, 17:12.
Julian Guest
15-10-2003, 12:14 Subject: CAN Bus Climatronic: Which Models Have It? |
Well, then take a closer look.
Gremlin Guest
15-10-2003, 13:15 Subject: CAN Bus Climatronic: Which Models Have It? |
That doesn't change the fact that, in my G4 plans, the Climatronic system doesn't have a CAN bus connection.
CU Gremlin.
Translated on 09-10-2026, 17:13.
Julian Guest
15-10-2003, 13:19 Subject: CAN Bus Climatronic: Which Models Have It? |
Nope, that just explains that you didn't check carefully. The Clima <5>5/99, in addition to the existing connection, MSG also provides a direct connection to Clima for supplying 70 channels instead of 44. Furthermore, there is also an extended connection to the Kombi unit.
If it's still not working for you, you unfortunately have incorrect plans. Any friendly person would be happy to help you further.
WarLord Guest
15-10-2003, 14:15 Subject: CAN Bus Climatronic: Which Models Have It? |
Okay, then I guess I'll have to start looking for a Climatronic unit from a Passat 35i. What features will be missing from the Climatronic if I don't retrofit the instrument cluster? This CAN bus stuff is really starting to annoy me.
Translated on 09-10-2026, 17:14.
Julian Guest
15-10-2003, 17:43 Subject: CAN Bus Climatronic: Which Models Have It? |
Okay, so if you're retrofitting a <5>5/99 becomes more complicated because you then need another generator (3 wires instead of 2), and you also need to use some additional functions from the MSG, etc.
Translated on 09-10-2026, 17:15.
WarLord Guest
15-10-2003, 20:35 Subject: CAN Bus Climatronic: Which Models Have It? |
Okay, since you seem to know about this stuff: Could you get me a wiring diagram for the Climatronic system in a Passat 35i B4? Because, I think I'd rather not use the Climatronic system from a Golf IV. It's just not designed for a Passat 35i B4.
Translated on 09-10-2026, 17:17.
