Audi A8 Injector Learn Procedure After Engine Replacement
VolkerA8
Post03-07-2017, 10:21    Subject: Audi A8 Injector Learn Procedure After Engine Replacement Quote
I had to replace the engine in my 2008 Audi A8 4.2 TDI BVN because the glow plugs broke/melted. I bought a used engine including all attachments, and now I need to program the "new" injectors to my "old" engine control units.
(Entering the encoding)
Can someone tell me the best way to proceed, and whether I need any special login codes? Unfortunately, very little information is stored for this engine in my VCDS system.
I would be very grateful for your help.
Volker
Translated on 24-09-2026, 23:49.
Post03-07-2017, 11:02    Subject: Audi A8 Injector Learn Procedure After Engine Replacement Quote
Hi Volker,
Which version of VCDS are you using? Please always use the latest version from your customer account.
Have you already found this topic about calibrating the injectors / entering the injector codes?
Translated on 24-09-2026, 23:50.
No new posts Audi A4 B7/8E 1.8T BFB - Shaking/Vibration after cold start Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Check TDI injectors with VCDS (Common Rail) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A3, Differential Failure After Mileage Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine replacement after engine failure: Do I need to res... Diesel Engine Technology
No new posts Motorsteuergerät 600 km nach Austausch Injektoren defekt On-Board Diagnostics (OBD)
No new posts T4 Engine Swap 102 hp to 150 hp ??? Diesel Engine Technology
No new posts Engine Replacement: Options & Costs Diesel Engine Technology
