Air conditioning / Module 08 > Adaptation > Channel IDE03253 - A/C comfort parameter for start-stop function > Old value: 5 > New value: 0.
The adjustment has successfully disabled the SSA.
In the AI system, whenever the SSA would normally become active, a white symbol indicating "not available" is displayed (a crossed-out starter icon).
There are no further issues, no stuttering, or anything like that.
The button (and the LED inside it) still function as intended, but their effect is not noticeable.
Despite the remaining negative effect (or, conversely, good for TÜV
), if the climate control unit is completely switched off (using the separate "off" button), the SSA function will also work normally again (in which case, the SSA deactivation button can be used).
"A/C off" alone can be used, while SSA remains "unavailable."
"Note:"
HEX-V2 with VCDS 17.8.
I have an "Audi A4 Avant Sport B9 2.0 TFSI ultra with S-Tronic transmission" that has a "three-zone climate control system."
