VCDS Mobile App for Sharan 7N
New Topic Reply 🔗 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
Sbrimmers
Post30-07-2017, 18:48    Subject: VCDS Mobile App for Sharan 7N Quote
I've now had my VCDS Hex Net for a week.
Okay, so I'm a beginner. I've tried using VCDS on my phone, and I'm having a problem where the "Advanced Measuring Values" aren't working correctly. It's displaying different values than the ones I've selected. For example, when I select "Engine RPM," it shows "selector lever position" instead. I did a full scan and saved it, but I can't seem to find it anymore. Where is it saved?
The car is a Sharan 7N, manufactured in 2015, with 4Motion all-wheel drive and a CFFB engine.
I also noted down the ASAM version: EV_ECM20TDI01103L906018HK 003013.
Thank you for your support.
Best regards, Stefan.
Translated on 09-07-2026, 10:23.
Sbrimmers
Post31-07-2017, 16:39    Subject: VCDS Mobile App for Sharan 7N Quote
Here's a translation:
"I copied this from Autoscan:"
Address 01: Engine (CFFB J623) Labels: 03-01.clb
Part No SW: 03L 906 018 HK HW: 03L 907 309 Q
Component: R4 2.0l TDI H28 9978
Revision: 44H28---
Coding: 0019001A043601080000
Shop #: WSC 00240 216 00000
ASAM Dataset: EV_ECM20TDI01103L906018HK 003013
ROD: EV_ECM20TDI01103L906018HK.rod
VCID: 7AB761EB46C9D1EFB3C740AA04-802F
Stefan.
Translated on 09-07-2026, 10:25.
Post01-08-2017, 11:49    Subject: VCDS Mobile App for Sharan 7N Quote
VCDS-Mobile is still in "beta," so please email your feedback to Ross-Tech. Also, using the VCIConfig.exe tool in the VCDS installation directory, make sure that your HEX-NET device has the latest firmware.
Translated on 09-07-2026, 10:27.
No new posts MKB ANU Engine Noises: Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Sharan 7M9, Engine Noises at MKB ANU Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Sharan 7M8, reduzierte Lenkunterstützung Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Announcements: VCDS-Mobile®, HEX-NET® Interface On-Board Diagnostics (OBD)
No new posts VCDS Mobile App not in Store On-Board Diagnostics (OBD)
No new posts VCDS Mobile: Incorrect Data Display? Fix Now! On-Board Diagnostics (OBD)
No new posts VCDS 11.11.5 is outdated, VCDS: Software is outdated On-Board Diagnostics (OBD)
