Marfan88
Joined: 08/02/2017 Posts: 5 Karma: +0 / -0 Location: Niedersachsen, Wilhelmshaven 2008 Volkswagen Passat Free account, no CAN development support
06-08-2017, 19:54 Subject: Parking Sensor Replacement: Fix Problems Now |
Hello and greetings...
"I've been dealing with this issue for a long time. Out of the blue, my parking sensors stopped working. When I put the car in reverse, there's a beeping sound for about 4 seconds, and the regular image from the rearview camera appears for the same amount of time, but then it disappears and the screen goes black. And the entire parking sensor system no longer functions. I can reproduce this problem repeatedly. The camera turns on, but then immediately turns off again."
I read the codes with VCDS, but I'm just not able to figure out what's going on with these errors. One error might be causing the others.
The first and simplest solution would be to replace all the sensors at the front, but I find that odd, because otherwise the scan should show the exact defective sensor.
I hope you can understand me; please find a freshly scanned image attached.
Thank you.
| Description: |
 Download |
| File name: |
Log-GK-3-WVWZZZ3CZ9E087507-187610km.txt |
| File size: |
24.33 KB |
| Downloaded: |
1058 times |
Translated on 28-08-2026, 5:47.
Profile PM Garage |
Joined: 04/12/2002 Posts: 18132 Karma: +804 / -0 Location: St.Gallen 2018 Volkswagen T6
06-08-2017, 19:59 Subject: Parking Sensor Replacement: Fix Problems Now |
The error is quite clear.
Quote: | 02069 - Sensor for front parking assistance.
011 - Interruption
01625 - Warning sound for front parking assist system (H22).
009 - Short circuit to ground - |
First, there's a faulty ultrasonic sensor located in the front bumper or its wiring. Additionally, the warning buzzer for the parking distance control (PDC) has a loose connection or is defective.
Translated on 28-08-2026, 5:49.
Profile PM WWW Garage |
Marfan88
06-08-2017, 20:27 Subject: Parking Sensor Replacement: Fix Problems Now |
I didn't interpret the term "interruption" as meaning a defect. Also, in other posts, the specific sensor that is broken is always mentioned, e.g., "middle, front, right." In my case, it only says "front." Should I replace all 6? Or should I buy one and then use a process of elimination?
Does "warning buzzer" refer to the "speaker" that produces the beeping sounds?
Thank you for the quick response.
Translated on 28-08-2026, 5:50.
Profile PM Garage |
vag-driver Profi-Schrauber
07-08-2017, 21:19 Subject: Parking Sensor Replacement: Fix Problems Now |
Marfan88 wrote: | Does the "buzzer" mean the "speaker" that makes the beeping sounds?
Yes.
Andreas
Translated on 28-08-2026, 5:51.
Marfan88
08-08-2017, 6:59 Subject: Parking Sensor Replacement: Fix Problems Now |
How can I identify a faulty cable? With a simple continuity test? I think that will be difficult because the connectors in the control unit are so complicated.
Thank you for the answers.
Translated on 28-08-2026, 5:52.
Profile PM Garage |
dieselschrauber and Rüdi likes this. |
08-08-2017, 7:28 Subject: Parking Sensor Replacement: Fix Problems Now |
Usually, the component itself is defective. In this case, it's the warning buzzer.
Andreas
Mpire Profi-Schrauber
Joined: 10/19/2009 Posts: 351 Karma: +192 / -0 Location: Oberpfalz 2019 Skoda Octavia Premium Support
dieselschrauber likes this. |
08-08-2017, 19:52 Subject: Parking Sensor Replacement: Fix Problems Now |
I've also experienced this issue before, where the exact sensor isn't displayed in the diagnostic information. It often depends on the parking distance control (PDC) module and its design/software.
But...
You can feel the defective parking sensor.
If, during the 4-second beep, you apply very slight pressure...
By placing a finger on the sensor surface, you can...
- vibration detected -> sensor OK.
- no sensation detected -> sensor malfunction.
It's easiest to go with two people, as you don't have to perform that awkward dance around the car within the 4-second time limit.
Good luck.
Regards, Mpire.
Translated on 28-08-2026, 5:53.
Profile PM Garage |
Marfan88
08-08-2017, 20:01 Subject: Parking Sensor Replacement: Fix Problems Now |
Thank you, I was really smiling while reading your post! I just imagined myself running around the car  !
Where are the warning alarms located for the front area?
Okay, has anyone here had experience with the really cheap sensors that cost around 10€? The "friendly" option costs 90€.
Thank you.
Translated on 28-08-2026, 5:54.
Profile PM Garage |
Herbert Profi-Schrauber
08-08-2017, 20:03 Subject: Parking Sensor Replacement: Fix Problems Now |
Quote: | How can I find a defect in the cables? With a simple continuity test? I think that will be difficult because the connectors in the control unit are so confusing.
Now you've received a tip. Otherwise, measure each wire individually. And inspect the relevant cable bundles. Diligence is a virtue for anyone who likes to tinker.
Translated on 28-08-2026, 5:55.
Marfan88
09-08-2017, 13:14 Subject: Parking Sensor Replacement: Fix Problems Now |
Thank you!
Yes, you are absolutely right! I will start working on it this weekend. Thank you for the answers.
I will contact you again if I have any problems.
Have a nice day.
Translated on 28-08-2026, 5:56.
Profile PM Garage |
