vag-driver Profi-Schrauber
13-03-2017, 22:08 Subject: Temperature Blend Door Actuator |
Today, I was unable to regulate the temperature on the driver's side of my Audi A4 B7. It always blows warm air. The passenger side, however, blows cool air as it should. The VCDS scan showed the following:
Address 08: Climate Control Module. Label file: DRV\8E0-820-043.lbl
Part number: 8E0 820 043 AM
Component: A4 Climate Control Unit, part number 2831.
Encoding: 00000
Operating number: WSC 00000
VCID: 6CD1F2B51CC04E2125-515A
"One error found:"
01809 - Temperature flap control motor, left (V158)
41-00 - Blocked or Floating
"Where is this motor located, and how can I access it? Should I simply obtain a replacement, or is there a way to repair it and make it functional again?" Viele Grüße
Andreas
Translated on 03-09-2026, 21:52.
14-03-2017, 7:46 Subject: Temperature Blend Door Actuator |
I now know how to expand it. The question remains whether and how it can be repaired.
"I would be interested in knowing the current part number so that I can obtain price quotes from other suppliers." Viele Grüße
Andreas
Translated on 03-09-2026, 21:54.
14-03-2017, 8:25 Subject: Temperature Blend Door Actuator |
Assuming we're talking about a vehicle with steering on the left, then it would be:
8E1 820 511 G, costs approximately €125. MfG. Michael
Profile PM Garage |
14-03-2017, 8:39 Subject: Temperature Blend Door Actuator |
Thank you. The Audi is left-hand drive. I assume that these engines are only available from the official Audi dealership. If not, I would be grateful for any alternative sources. Viele Grüße
Andreas
Translated on 03-09-2026, 21:55.
Kenny7
14-03-2017, 19:22 Subject: Temperature Blend Door Actuator |
"For the Passat, all the parts are available from Bosch and are about 20% cheaper than buying them directly from the dealership. It's the same situation for the Audi B6, and I suspect it's also the case for the B7, but I'm not entirely sure."
olli Profi-Schrauber
Joined: 05/24/2002 Posts: 581 Karma: +46 / -0 Location: Berlin
14-03-2017, 19:48 Subject: Temperature Blend Door Actuator |
The climate control motors from the A6 C4 could be relatively easily repaired. The only difficult part was the removal process.
If the casing is screwed on, you should find a kind of model motor inside. This collects a lot of debris from the carbon brushes on the commutator. This debris eventually becomes conductive, so the current essentially bypasses the motor. Cleaning the commutator and running the motor, slightly disassembled, on a laboratory power supply has helped a lot (at least for a few years  ).
I can't tell you whether the components are structured similarly in the B7 model...
Best regards from Berlin.
olli A6 CANA/JME /
Ex-A6 AEL
Translated on 03-09-2026, 21:56.
15-03-2017, 8:32 Subject: Temperature Blend Door Actuator |
Thank you for your replies. I will report back when I address the issue. Yesterday, I called the Bosch service, and they were unable to provide me with the part number 8E1 820 511 G. Their comment was that Bosch may no longer be allowed to sell the motors directly  . Viele Grüße
Andreas
Translated on 03-09-2026, 21:57.
15-03-2017, 8:59 Subject: Temperature Blend Door Actuator |
Original equipment suppliers for these engines are typically Hella or Valeo.
My two wholesalers can't offer me anything either; they probably aren't authorized to sell accessories. MfG. Michael
Translated on 03-09-2026, 21:58.
Profile PM Garage |
15-03-2017, 9:05 Subject: Temperature Blend Door Actuator |
TDI-GTI-4-Motion wrote: | Original equipment manufacturers for such engines are usually Hella or Valeo.
My two wholesalers can't offer me anything either; they probably aren't authorized to sell accessories. |
It has now become fashionable for ET companies to lock down their products for the aftermarket.  Viele Grüße
Andreas
Translated on 03-09-2026, 21:59.
dieselschrauber likes this. |
28-04-2017, 21:24 Subject: Temperature Blend Door Actuator |
After disassembling and opening the servo motor, I observed that the plastic gears were very difficult to turn. I tested the motor's functionality by connecting it to the battery, and it worked. Therefore, I manually moved the mechanism back and forth several times and also lubricated it with grease. Now, I can adjust the temperature as desired.
I suspect that the plastic wheels may have become stuck due to prolonged inactivity, and the motor's power was not sufficient to drive them. Viele Grüße
Andreas
microwave
14-09-2017, 19:55 Subject: Temperature Blend Door Actuator |
Hey,
I'm new here and I'm having the exact same problem. Could you briefly explain where the servo motor for the left temperature flap is located and how to remove it?
I am grateful for any advice.
Translated on 03-09-2026, 22:00.
14-09-2017, 20:57 Subject: Temperature Blend Door Actuator |
First, remove the cover located under the steering wheel. Then, you will see the motor that controls the flap, located to the right of the electronic throttle. Remove this motor and carefully open the housing. Viele Grüße
Andreas
Translated on 03-09-2026, 22:01.
microwave
15-09-2017, 10:35 Subject: Temperature Blend Door Actuator |
That sounds doable. Thank you very much, that helps me a lot!
I'll take care of it over the weekend.
Best regards!
