What signal comes from the clutch position sensor G476 Pin4?
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
habmichlieb
Post16-09-2017, 14:38    Subject: What signal comes from the clutch position sensor G476 Pin4? Quote
It concerns the hall sensor (coupling position sensor G476) on the coupling cylinder.
I am interested in knowing what signal is connected to pin 4 when the clutch pedal is fully depressed.
If I correctly interpret the wiring diagram, then pin 4 is responsible for ensuring that the engine only starts when the clutch is engaged.
Pin 4 of the G476 goes to the BnStg T16/7. This should then be the connector at position E. There is indicated in the wiring diagram that (for a switch) this pin 7 is connected to ground.
So, I understand correctly that the G476 mass is sent to pin 7 of the E-slot of the BnStg, thereby giving the OK for the motor to start?
Vehicle: VW Passat 3C, CBAB, Model Year 2009, 6-speed manual transmission.
Post16-09-2017, 17:18    Subject: What signal comes from the clutch position sensor G476 Pin4? Quote
So, ich verstehe also richtig, dass der G476-Signal an Pin 7 des Steckers E vom BnStg gesendet wird, und dadurch wird der Motorstart autorisiert?
Disclaimer: I see it the same way.
Best regards, Rainer
habmichlieb
Post16-09-2017, 23:21    Subject: What signal comes from the clutch position sensor G476 Pin4? Quote
So könnte ich also mit einem Signal an Pin 7 das Betätigen der Kupplung simulieren?
Z.B. Ignition with a 3-second timer?
habmichlieb
dieselschrauber likes this.
Post22-09-2017, 20:39    Subject: What signal comes from the clutch position sensor G476 Pin4? Quote
Feedback on the topic.
Yes, the mass is transmitted from the clutch position sensor to pin 7.
No new posts TDI: Frequent Regeneration? Where Does All the Soot Come ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J Clutch Pedal Not Returning Fully Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ASV Error: 'Engine Speed Sensor G80 - No Signal' Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Clutch position sensor (G476) Diesel Engine Technology
No new posts Signal too slow, signal too fat 3.0 TDI CTBA Diesel Engine Technology
No new posts 3BG AVF: Where does the oil come from? Diesel Engine Technology
No new posts Where does the water drain? Transmission, Chassis, Body & Interior
