Terminal 58d - Short circuit to ground
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
kossmann
2016 Audi Q3
Post19-09-2017, 7:49    Subject: Terminal 58d - Short circuit to ground Quote
Hello everyone,
I have the following error code in the control unit J519 of an Audi RS Q3, and I can't find the cause.
Code:
01064 - Klemme 58d - Dimmung Innenlicht
            007 - Kurzschluss nach Masse
             Umgebungsbedingungen:
                    Fehlerstatus: 01100111
                    Fehlerpriorität: 4
                    Fehlerhäufigkeit: 1
                    Verlernzähler: 5
                    Kilometerstand: 11670 km
                    Zeitangabe: 0
                    Datum: 2017.08.30
                    Zeit: 18:06:19
                        Kl.15 EIN
                    Spannung: 13.70 V
                        ein
                        ein
                        Kl.50 EIN
                        aus
                        aus
All switches, both front footwell lights, both Bose speakers, both 12V sockets in the center console, both lights above the sun visors, all reading lights in the headliner and trunk are working correctly. Otherwise, I don't see anything unusual.
Even http://wiki.ross-tech.com/wiki/index.php/01064 doesn't really help me. As I said, the lights inside are working, and even the light switch itself seems to be fine.
Ich hatte mal die Leuchte im Handschuhfach gegen eine original LED getauscht (habe LED-Innenraum-Paket, nur das Handschuhfach ist noch Glßhobst), dies aber wieder rßckgängig gemacht, da ich hier die Ursache vermutet habe. Lewithout success.
Does anyone have any other ideas about what might be causing this error? It's been in the control unit for at least half a year, and it reappears relatively quickly after being cleared.
Translated on 21-07-2026, 19:31.
Post19-09-2017, 8:52    Subject: Terminal 58d - Short circuit to ground Quote
Perhaps the coding of the vehicle's onboard computer was incorrectly modified, and a pin is now wired differently than what the control unit expects?
Translated on 21-07-2026, 19:33.
kossmann
2016 Audi Q3
Post19-09-2017, 9:00    Subject: Terminal 58d - Short circuit to ground Quote
The idea itself is not bad.
In the control unit 09, I once experimentally programmed the function "alarm system acknowledgment when opening and closing," but I actually reversed that setting.
Currently, the situation is as follows (there are errors present).
Code:
Adresse 09: Zentralelektrik (J519)       Labeldatei: 8X0-907-063.clb
   Teilenummer SW: 8X0 907 063 AF    HW: 8X0 907 063 AF
   Bauteil: BCM PQ35  M   113 0819
   Revision: AA113819
   Codierung: 46000A2FA801F3C0241849C82184014C53F327AA016F81BBE40887A4E0C5
After delivery, it looked like this (no errors present):
Code:
   Revision: AA113819
   Codierung: 46000A2FA805F3C0241849C82184014C53F327AA016F81BBE40887A4E0C5
There's indeed a difference at the 12th position (now "1" instead of the previous "5") – that even belongs to byte 5, which I was messing with, right? I need to take a closer look at that. Thanks!
Translated on 21-07-2026, 19:34.
Post19-09-2017, 9:17    Subject: Terminal 58d - Short circuit to ground Quote
I'm really curious icon_smile.gif.
Translated on 21-07-2026, 19:35.
kossmann
2016 Audi Q3
dieselschrauber likes this.
Post19-09-2017, 17:39    Subject: Terminal 58d - Short circuit to ground Quote
That didn't achieve anything. While bit 2 in byte 5 was still disabled ("Horn Confirmation Adaptation blocked (Adaptation Channel 010/011 & MFA+/FIS/MMI)") – for some reason that's written in English – it has nothing to do with the lighting, and furthermore, it didn't fix the problem; the error immediately reappears.
However, I did notice something about the light switch itself. The outer symbols only glow faintly and briefly after the ignition is turned on, and then they go dark, while the inner ones continue to shine brightly. This initially looks strange and could indicate a short circuit in the switch itself - which, at least, lasted for 3 months after delivery icon_wink.gif.
kossmann
2016 Audi Q3
Post28-09-2017, 15:58    Subject: Terminal 58d - Short circuit to ground Quote
Current status: The car was at the workshop today, but the problem isn't with the light switch itself (the lights in the overhead console aren't working either). Instead, the control unit is not sending the corresponding signal. A new control unit has been ordered.
Translated on 21-07-2026, 19:36.
kossmann
2016 Audi Q3
Post09-10-2017, 14:56    Subject: Terminal 58d - Short circuit to ground Quote
New control unit, same error. The wiring harness has now been inspected and it was found that three cables are pinched under the center console from the factory and are shorting to ground. The wiring harness is now being repaired.
Translated on 21-07-2026, 19:37.
No new posts Error code 005399 / P1517 - Short circuit to ground Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Short circuit Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A3, Differential Failure After Mileage Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Intake air temperature sensor (G72) - Short circuit to gr... On-Board Diagnostics (OBD)
No new posts Temperature Sensor Errors: Short Circuit to Ground Diesel Engine Technology
No new posts High-pressure generator (G65) 009 - Ground interruption/s... Transmission, Chassis, Body & Interior
No new posts Audi 8E RS4 Signal for Engine Immobilizer Short to Ground On-Board Diagnostics (OBD)
