The air conditioner is not heating
awek
Post24-10-2003, 9:29    Subject: The air conditioner is not heating Quote
Hello and have a nice day icon_smile.gif.
I've recently been having a problem with the air conditioning system in my Audi A6 (C4) 2.5 TDI.
The air conditioner is no longer heating.
The troubleshooting revealed the following:
2 errors detected.
01271 041
Temperature flap control motor - V68.
blocked or de-energized
01274 041
Actuator for pressure relief valve - V71.
That looks like an electrical problem to me!
Can anyone give me a hint as to how the servo motors receive their power?
Is there a relay or something like that?
I'm a bit lost, actually.
Gremlin
Post24-10-2003, 12:46    Subject: The air conditioner is not heating Quote
Good question:
In the Golf/Bora/Octavia Climatronic system, the servo motors receive their power directly from the Climatronic control unit.
It's best to start by searching for the servo motors and checking the cables and connectors first. Then, connect a multimeter and start an actuator diagnosis (I believe Audi also has a way to do this with a 'trick'). Wait and see what happens. Although it's rare, it's possible for two motors to fail at the same time. Or, some debris might have gotten in and is blocking the flaps.
CU Gremlin.
awek
Post24-10-2003, 13:07    Subject: The air conditioner is not heating Quote
mmmh...
Okay, so I think that if there are no more components between the control unit and the actuator, then the control unit is probably working correctly. That would have likely indicated the diagnosis.
So, are the actuators mechanically blocked or are the cables loose?!
So, where are these things located?
In the center console or under the cover in the engine compartment?
I haven't disassembled the interior yet.
Who knows what?
Thank you very much.
AWEK
No new posts Passat 3C air conditioning not cooling General Tips
No new posts A3 Climate Control Not Working: Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Empty the air conditioner Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat Heater Not Working: 2000 1.9PD Fix Diesel Engine Technology
No new posts Manual air conditioning system not working. Transmission, Chassis, Body & Interior
No new posts Air conditioner not cooling during speed fluctuations Transmission, Chassis, Body & Interior
No new posts AC Disinfection: Why It's Not Working! Transmission, Chassis, Body & Interior
