Jan6K
31-01-2005, 0:24 Subject: |
Mine is MJ 02... but there should also be a "1H" designation. I inquired about that before, and I'll check again when it's warmer and drier.
Jan. 1Z5 CFHF  / AHB H4D
Translated on 13-09-2026, 13:58.
31-01-2005, 0:35 Subject: |
"The reliable source" also indicates 1H0 for the MJ02.
Have fun with frost heaving  .
m; Transparency, Teamwork
Profile PM Garage |
Jan6K
31-01-2005, 10:00 Subject: |
I know... but I've also held GP01 schematics where even the wire colors were wrong, let alone everything else.
Translated on 13-09-2026, 13:59.
31-01-2005, 12:39 Subject: |
Did the Dutch people get too high while assembling your tractor?
"I see colors."
Profile PM Garage |
reuselkopp Blaumann
01-10-2005, 18:12 Subject: |
I know this post is quite old, but I'm curious to know if there's any update on the theories, specifically whether the two pressure transducers are truly technically identical? The electrical connections are different, but what about the technology itself?
Greetings.
Reuselkopp.
Translated on 13-09-2026, 14:00.
reuselkopp Blaumann
10-01-2006, 8:43 Subject: |
Are there any new findings on this topic yet?
Reuselkopp.
VIP Guest
15-06-2018, 0:26 Subject: SEO-Optimized Website: Update & Best Practices |
Hello everyone
I would like to contribute in a solution-oriented way.
I have both a working vehicle with the 1H0 part and one with the 1J0 part available here.
Should I measure anything else besides the resistance using my high-quality measuring device?
bb
Translated on 13-09-2026, 14:01.
Joined: 04/12/2002 Posts: 18118 Karma: +801 / -0 Location: St.Gallen 2018 Volkswagen T6
15-06-2018, 8:53 Subject: Update: New features and improvements |
VIP wrote: | | I would like to contribute in a solution-oriented way | .
Really?  So, first of all, the interest is likely to be limited 12 years after the question was asked, and then the resistance of the coils is practically irrelevant; it's about which control signal allows each solenoid valve to pass a certain amount of airflow.
You can't measure that so easily, and nowadays, I doubt anyone is even interested in it anymore.
Translated on 13-09-2026, 14:02.
Profile PM WWW Garage |
