Air Quality Sensor Replacement: Golf 7 Error Persists
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
taxidriverpro
Post22-08-2018, 17:20    Subject: Air Quality Sensor Replacement: Golf 7 Error Persists Quote
Hello everyone,
I have a Golf 7 manufactured in 2015, and when I had the diagnostic codes read, it showed a faulty air quality sensor.
I bought a new one and installed it briefly.
Unfortunately, the error is still there...
You can't find anything about the Golf 7 on Google, but you can find information about other VW models.
There, I read that the problem could also be caused by a faulty fuse, which is why the radiator fan would also run continuously in case of a defect.
I can't test the running functionality right now because it's constantly running. I also checked the fuses, but I didn't find anything that matches the description.
Could this also be related to a fuse issue in a Golf 7, or what else could be the reason why the new sensor isn't working either?
I don't want to go to VW; they'll probably just replace the entire Climatronic control unit.
Thank you in advance for your tips.
Fredy.
Log-FS-YF44-WVWZZZAUZFP092234-78086km.txt
 File name:  Log-FS-YF44-WVWZZZAUZFP092234-78086km.txt
 File size:  17.09 KB
 Downloaded:  954 times
Translated on 17-10-2026, 8:20.
Post22-08-2018, 17:42    Subject: Air Quality Sensor Replacement: Golf 7 Error Persists Quote
Please provide a complete scan of the entire sensor assembly. In addition to the sensor itself, the wiring and connector plugs should also be considered.
Translated on 17-10-2026, 8:22.
taxidriverpro
Post22-08-2018, 20:25    Subject: Air Quality Sensor Replacement: Golf 7 Error Persists Quote
I have uploaded it.
Post22-08-2018, 21:01    Subject: Air Quality Sensor Replacement: Golf 7 Error Persists Quote
Thank you.
Air quality sensor.
B10AF 31 [009] - no signal
As I suspected. A "no signal" error can be caused by various issues, ranging from cable problems to a faulty sensor, and so on.
I suggest you get the wiring diagram for your car from Erwin (siehe Fehlerdatenbank) and check how the sensor is connected.
Translated on 17-10-2026, 8:23.
vag-driver
dieselschrauber likes this.
Post23-08-2018, 6:54    Subject: Air Quality Sensor Replacement: Golf 7 Error Persists Quote
Did you install a new VW sensor? Perhaps that one is also defective...
Otherwise, as Rainer mentioned, trace back the circuit diagram and check it.
Another idea:
Do you have the possibility to test the sensors on another vehicle?
Andreas
Translated on 17-10-2026, 8:24.
No new posts P246E - Exhaust Gas Temperature Sensor (EGS) Bank 1 Sensor 4 General Tips
No new posts VW Golf V/VI and similar models: ABS/ESP error Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Golf 1J, Problem with the ignition lock Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AGR Valve Replacement Problems Diesel Engine Technology
No new posts Diesel leaking from the return line (AEL) after ESD repla... Diesel Engine Technology
No new posts More Problems After Major Upgrade. Diesel Engine Technology
No new posts Car Door Problems: Troubleshooting & Repair On-Board Diagnostics (OBD)
