Rumbling ticking sounds, Sharan 7N CFFB
R082rt7971
2006 Audi A4
Post11-08-2018, 17:56    Subject: Rumbling ticking sounds, Sharan 7N CFFB Quote
Hello friends!
I can hear an undefined rattling sound coming from the engine compartment. The best way is to listen while doing light ascents and descents.
Perhaps someone recognizes the sound.
Post11-08-2018, 20:33    Subject: Rumbling ticking sounds, Sharan 7N CFFB Quote
Please upload the files/videos related to the topic. Thank you.
Best regards, Rainer
R082rt7971
2006 Audi A4
Post12-08-2018, 11:01    Subject: Rumbling ticking sounds, Sharan 7N CFFB Quote
Sorry, the information was a bit superficial.
It is a VW Sharan 7N 2.0tdi CFFB.
I have provided the original vehicle with the described noise again. The noise occurs only a few seconds after the engine starts and then at a speed of approximately 1050 min^-1. Injections are to be excluded.
I was able to identify the cause of the noise in the engine compartment after a long search, as the noise was coming from the high-pressure pump. After disconnecting the plug, the noise disappeared.
Now my question: Does anyone know about this problem and could the part simply be replaced? Or is the problem here to be found in something deeper?
Best regards, Robert
Rumbling ticking sounds, Sharan 7N CFFB - 20180811_223158.mp4
 File size:  64.47 MB
 Viewed:  2186 times
Post12-08-2018, 11:18    Subject: Rumbling ticking sounds, Sharan 7N CFFB Quote
The ticking sounds almost certainly come from the solenoid valve located directly above the oil filter.
If you find out how to remove them and you can dismantle the magnetic valve without damaging it,
Another possible source of noise is the plastic pipes on and around the air filter box, and its cover. There might already be a relevant article on this topic.
R082rt7971
2006 Audi A4
Post12-08-2018, 11:36    Subject: Rumbling ticking sounds, Sharan 7N CFFB Quote
 File size:  1.63 MB
 Viewed:  788 times
Hufe
Karma: +22 / -0   Thank you, like it!
2004 Audi A6 Avant
dieselschrauber and R082rt7971 likes this.
Post14-08-2018, 9:04    Subject: Throttle Disconnect Quote
I have also experienced the same noise with the CFHC (Tiguan 2.0 CR). It mainly occurs when changing gears into lower gears up to approximately 1000 RPM. Good to hear when driving along a wall with the window open.
I initially thought it was a "defect" in the DSG. However, it's actually coming from the HD pump area. Specifically, it's coming from valve N290 - the fuel dosing valve. Description: Regulates the amount of fuel required for compression based on need.
So, a modern sliding door closure.
Beste Grüße,
Hufe
R082rt7971
2006 Audi A4
dieselschrauber likes this.
Post12-11-2018, 12:19    Subject: Rumbling ticking sounds, Sharan 7N CFFB Quote
Thank you for the message!
To conclude this topic after a long time.
It is valve N290 that is causing this ticking sound. Comparable engines produce the same sounds.
Seems to be normal. One is a bit louder, the other is a bit quieter.
Hi Robert!
No new posts Doku Sharan 7M9, Engine Noises at MKB ANU Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts MKB ANU Engine Noises: Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Climatronic Error: Doku Sharan 7M8 Fix Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts CLLB instead of CFFB in Sharan 7N Diesel Engine Technology
No new posts Sharan DPF: Regenerates Every 30km Diesel Engine Technology
No new posts Rattling noise at idle Diesel Engine Technology
No new posts Rattle Noise CR TDI CFBG Engine - Diagnosis Diesel Engine Technology
