Engine Removal 2.0 CR
jarobaldu
Karma: +40 / -0   Thank you, like it!
dieselschrauber likes this.
Post26-09-2018, 8:15    Subject: Engine Removal 2.0 CR Quote
I have a 2009 Passat with a 2.0 CR engine that needs to be replaced due to metal shavings in the high-pressure pump.
The engine needs to be removed from the front, but the exhaust bracket is now obstructing the final section. VW RLF says: Remove the engine mount with the steering rack. Is there a trick to remove the engine without having to remove the steering rack?
LG
Jaro.
AUDI A6 C4 1995 ABC/CRD
Fiat 124 Spider, Bj. 80
Karma: +642 / -0   Thank you, like it!
Post27-09-2018, 7:55    Subject: Engine Removal 2.0 CR Quote
Are you building something together with Getriebe?
A picture of the problematic part would definitely be helpful.
jarobaldu
Post27-09-2018, 9:02    Subject: Engine Removal 2.0 CR Quote
Yes, with a gearbox. I've now found the solution: Remove the exhaust with DOF, disconnect the driveshaft, and detach the DPF.
I'll continue on Friday, and I'll let you know.
Jaro.
jarobaldu
Post13-02-2019, 11:27    Subject: Engine Removal 2.0 CR Quote
So, the expansion worked out back then:
1) Remove the clamp between the DPF (Diesel Particulate Filter) and the exhaust manifold.
2) Engine and transmission facing forward.
The DPF could therefore remain installed on the vehicle.
LG
Adrian.
No new posts DPF removal for Passat 3C with BMP engine Troubleshooting & Guides
No new posts Is it possible to install a G40 engine without replacing ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AJM Motor - Motor klappert, Leistungsmangel, Schwarzrauch Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Problem beim Ausbau der ESP VP37 beim AEL-Motor (A6 2,5 TDI) Diesel Engine Technology
No new posts Ausbau Concert 2 Transmission, Chassis, Body & Interior
No new posts Help with expanding the AGR (Gasoline Return) system on a... Diesel Engine Technology
No new posts AGR ohne Ausbau reinigen Diesel Engine Technology
