Golf 7 VCDS: Troubleshooting Access Issues
Post02-02-2019, 15:32    Subject: Golf 7 VCDS: Troubleshooting Access Issues Quote
The reason for my post is that I am unable to initiate a service regeneration while driving my Golf 7 (DDYA).
VCDS versions 17.8 and then 18.9 were used on Windows 7, with a HEX+CAN interface.
Here's what I'm observing in detail:
- Alle meines Wissens vorhandenen Steuergeräte tauchen im Autoscan auf (sh. Appendix).
- Intermittent errors can be cleared, for example, in the Climatronic system.
STG1 (Engine):
- Default setting – Particle filter service regeneration: "This service is not supported in the current session."
- Actuator diagnosis - radiator fan control: "Rejected by the control unit".
- Attempted login using the code displayed by VCDS 18.9 (27971). Error: "Control unit does not send a seed."
- Reading extended measurement data is working.
STG 17 (Terminal block):
- Actuator diagnosis – warning buzzer (?) – functioning.
- Actuator diagnosis - indicator lights - "rejected by the control unit".
- Modification of the APK to change the "Ignition Active" message is working; modification to change "TFL via BAP or sequence" is working.
I am aware that the HEX+CAN interface does not recognize all control units (ECUs) in the Golf 7. However, I am surprised that it only works with some ECUs partially.
Could there be another cause?
Log-WVWZZZAUZJW119781-16902km.txt
 File name:  Log-WVWZZZAUZJW119781-16902km.txt
 File size:  11.94 KB
 Downloaded:  523 times
Translated on 21-09-2026, 16:13.
Post02-02-2019, 16:50    Subject: Golf 7 VCDS: Troubleshooting Access Issues Quote
Hello Herbert,
According to the vehicle identification number, the model year of your Golf is 2018. For vehicles of that year or newer, there was the HEX-V2 or HEX-NET system available.
Unfortunately, I can't say exactly what's going wrong with you, as I didn't program that. icon_cool.gif
My guess is that it's due to that. So far, everything I've tried has worked on my 2018 T6, but a forced regeneration hasn't been necessary (or, fortunately, hasn't been required).
There might be other experiences out there, but I only work on my own vehicles.
Translated on 21-09-2026, 16:15.
Post02-02-2019, 17:51    Subject: Golf 7 VCDS Issues: Troubleshooting & Solutions Quote
Hi Rainer,
I'll wait a bit to see if anyone else knows anything about this topic.
Otherwise, it essentially amounts to a HEX-V2. The 10 VIN version is probably correct.
Translated on 21-09-2026, 16:17.
dieselschrauber likes this.
Post23-02-2019, 17:37    Subject: Golf 7 VCDS: Troubleshooting Access Issues Quote
It is now clear that, with the 2018 Golf, the control units that are found during the car scan are not fully accessible via HEX+CAN.
With HEX-V2, it works - for example, on the engine control unit, you can perform actuator diagnostics, service regeneration, and unlocking functions.
It's likely that this can also be applied to other, more recent models.
Translated on 21-09-2026, 16:18.
No new posts Brake Bleeding with VCDS: A Complete Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Battery Status with VCDS Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Train T90 / T 91 with VCDS Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS HEX-V2 - Service reminder reset for Golf VII On-Board Diagnostics (OBD)
No new posts Golf VII GTI: Bleed Cooling System with VCDS On-Board Diagnostics (OBD)
No new posts Golf 6 TDI: VCDS Scan & Review Diesel Engine Technology
No new posts TDI ALH: Can't Adjust Injection Timing with VCDS? Diesel Engine Technology
