Ignition Off Time Signal: 7781 Code
kossmann
2016 Audi Q3
Post24-06-2019, 17:45    Subject: Ignition Off Time Signal: 7781 Code Quote
Hello everyone,
Can someone possibly help me understand the following error message?
Code:
Adresse 01: Motorelektronik (------CZGB)       Labeldatei:. DRV\07K-907-309-V1.clb
   Teilenummer SW: 8U0 907 404 C    HW: 07K 907 309 D
   Bauteil: 2.5l R5/4V TF X54 0001
   Revision: NIX54---
   Codierung: 32250032253609033620
   ASAM Datensatz: EV_ECM25TFS0118U0907404C 001001
   ROD: EV_ECM25TFS0118U0907404C.rod
   VCID: 38749EFB8365EF8A25-806C
1 Fehler gefunden:
7781 - Signal für Zeitspanne Zündung aus
          P150A 00 [032] - unplausibel
          Sporadisch - unbestätigt - geprüft seit letzter Löschung
             Umgebungsbedingungen:
                    Fehlerstatus: 00000001
                    Fehlerpriorität: 2
                    Fehlerhäufigkeit: 1
                    Kilometerstand: 20061 km
                    Datum: 2019.06.14
                    Zeit: 15:29:56
                    Motordrehzahl: 239.00 /min
                    Normierter Lastwert: 54.9 %
                    Fahrzeuggeschwindigkeit: 0 km/h
                    Kühlmitteltemperatur: 17 °C
                    Ansauglufttemperatur: 18 °C
                    Umgebungsluftdruck: 1000 mbar
                    Spannung Klemme 30: 10.160 V
                    Verlernzähler nach OBD: 35
                    Status des Motors: COENG_CRANKING
                    Status des Motors-Test_Program_Co Eng st COMPU VERB UBYTE: 2
According to the date and time, I must have started the car there, and then drove normally (without any problems). The return trip was also uneventful, and the subsequent 2-4 engine starts (covering a distance of 40 km) have also been fine.
Could something like this happen occasionally, or does it indicate a potentially larger, upcoming problem? And what exactly is it?
Translated on 01-09-2026, 1:19.
Post24-06-2019, 18:02    Subject: Ignition Off Time Signal: 7781 Code Quote
I suspect it's a message on the CAN bus, specifically "Ignition off duration," that is being incorrectly transmitted by the engine control unit.
It's likely due to a low battery voltage; the voltage readings in the current environment are around 10.x V.
Therefore, and unless any modifications have been made to the engine control unit, instrument cluster, or immobilizer, it is best to wait and see.
Clear the error and see if it reappears.
Translated on 01-09-2026, 1:21.
kossmann
2016 Audi Q3
Post24-06-2019, 18:15    Subject: Ignition Off Time Signal: 7781 Code Quote
Okay, thank you.
"Nothing modified" is, of course, relative. It has different software installed and different spark plugs, but that's all been the case for "ages," and the engine control unit (ECU) has never complained about it.
I need to check the battery voltage. It's also possible that the starter motor drained it during startup, right?
Translated on 01-09-2026, 1:22.
Post24-06-2019, 19:13    Subject: Ignition Off Time Signal: 7781 Code Quote
kossmann wrote:
I need to take a look at the battery voltage. But it's also possible that it was drained by the starter motor during startup, right?
Yes, as I said, I would first continue to observe.
Translated on 01-09-2026, 1:23.
No new posts ASV Error: 'Engine Speed Sensor G80 - No Signal' Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Low turbocharger pressure sensor signal error Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P0101 Error Code: Mass Air Flow Sensor Problem Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Signal too slow, signal too fat 3.0 TDI CTBA Diesel Engine Technology
No new posts Supply voltage for steering angle sensor G85: Ignition an... On-Board Diagnostics (OBD)
No new posts V6 ABC Engine: VCDS Ignition Base Setup (1996) On-Board Diagnostics (OBD)
No new posts Ignition: On/Off at Battery Ground Connection Diesel Engine Technology
