VCDS Mobile App not in Store
New Topic Reply 🔗 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
Post01-09-2019, 14:49    Subject: VCDS Mobile App not in Store Quote
Hello Mr. ****
In effect, the "app" simply opens a web browser with the IP address of the HEX-NET, essentially using the URL.
http://192.168.0.1
You can simply open the web browser on your mobile phone and enter the configured IP address. If it is incorrect, you can find out the correct IP address using the Windows VCIConfig tool or by clicking on "Connection Test" in the VCDS program settings.
I simply created a link to the above address on my phone.
Best regards, Rainer Kaufmann
No new posts VCDS: HEX-USB CAN adapter not found after update General Tips
No new posts VCDS: Resetting DSG Transmission Settings Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Battery Status with VCDS Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS Mobile: Incorrect Data Display? Fix Now! On-Board Diagnostics (OBD)
No new posts Announcements: VCDS-Mobile®, HEX-NET® Interface On-Board Diagnostics (OBD)
No new posts VCDS Mobile App for Sharan 7N On-Board Diagnostics (OBD)
No new posts VCDS does not recognize Skoda Octavia; Gateway not supported On-Board Diagnostics (OBD)
