Parking assist malfunction
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
Hufe
Karma: +22 / -0   Thank you, like it!
2004 Audi A6 Avant
dieselschrauber likes this.
Post17-07-2019, 19:21    Subject: Parking assist malfunction Quote
Hello everyone,
My parking assist system is no longer beeping.
VCDS indicated that a sensor was faulty, which I replaced. Now, all 4 sensors are providing correct values, but there's still no sound.
Error memory is empty.
Could you tell me which PIN output on control unit 8Z0 919 283 (parking assist control unit, manufacturer SWF) is responsible for the sound? Then I could check if the control unit is faulty or if the speaker is defective.
"Thank you!!"
Beste Grüße,
Hufe
vag-driver
Post22-07-2019, 12:02    Subject: Parking assist malfunction Quote
I would measure the voltage at the beeper. Mine was also defective on my A4. It is highly likely that the wire connecting to the diaphragm inside the device has broken.
Andreas
Hufe
2004 Audi A6 Avant
Post26-09-2019, 7:58    Subject: Parking assist malfunction Quote
Better late than never: The solution.
The speaker was defective. I was able to measure the output signal in the range of 0.0...V.
I tested it using an old speaker from a walkie-talkie.
Beste Grüße,
Hufe
Post28-09-2019, 9:56    Subject: Parking assist malfunction Translating...
[Translating...]
No new posts Doku A6 4B, Einparkhilfe defekt Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Parking Assist Failure: Audi A2 8Z0 MJ 2002 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts C4 AEL Kühlwassertemp-Anzeige defekt Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Parking Assist T5 Electrical Systems, Vehicle Electronics, Multimedia
No new posts Does the parking assist sensor 4D0 919 283 support traile... Electrical Systems, Vehicle Electronics, Multimedia
No new posts Geber für Einparkhilfe-Probleme Electrical Systems, Vehicle Electronics, Multimedia
No new posts Retrofitting front parking sensors Electrical Systems, Vehicle Electronics, Multimedia
