Audi A3 8P Wheel Bearing Housing & Shock Absorber
Post21-09-2019, 11:25    Subject: Audi A3 8P Wheel Bearing Housing & Shock Absorber Quote
For an Audi A3 8P, the wheel bearing housing, including the wheel bearing, needs to be replaced.
Does anyone know if the shock absorber/strut assembly can be separated from the wheel bearing without special tools?
Translated on 27-10-2026, 18:08.
dieselschrauber likes this.
Post21-09-2019, 11:41    Subject: Best German Recipes: Authentic & Easy Quote
Is this the version where the shock absorber is attached to the wheel bearing housing with a pin at the top?
Remove the clamping screw, apply Caramba, and if necessary, carefully widen the gap (without bending).
Translated on 27-10-2026, 18:09.
Post21-09-2019, 12:31    Subject: Audi A3 8P Wheel Bearing Housing & Shock Absorber Quote
Hello Herbert,
Thank you, Rainer.
 File size:  1.68 MB
 Viewed:  1059 times
Karma: +645 / -0   Thank you, like it!
Post22-09-2019, 8:37    Subject: Audi A3 8P Wheel Bearing Housing & Shock Absorber Quote
The wheel bearing housing needs to be spread open in the slot. You can buy a 1/2" socket specifically for VW Golf V and similar models for a reasonable price. It's best to remove the entire shock absorber assembly. It's easier to do in a vise, but it's very important to blow out the 3 threaded holes where the strut mount is attached with compressed air from underneath. Then, soak them repeatedly with rust remover, and carefully unscrew the bolts. Try to avoid loosening the nuts at the bottom; if they do come loose, you'll need to weld them back on. It's a good idea to have new strut mounts on hand just in case.
Translated on 27-10-2026, 18:10.
klahaui
Avatar-klahaui
2019 Volkswagen Golf
Post24-09-2019, 19:41    Subject: Audi A3 8P Wheel Bearing Housing & Shock Absorber Quote
Evening.
To create a wedge, I filed the threads of an M10 screw to make them oval. It works very well and costs almost nothing.
If you need to adjust the camber on the control arm, you can use a special adjustment bolt, but a regular bolt can also be used for the connection.
Spray some oil into the rear slot; it will then slide more easily icon_smile_thumb_up.gif.
Thilo.
Translated on 27-10-2026, 18:11.
Post26-09-2019, 17:33    Subject: Audi A3 8P Wheel Bearing Housing & Shock Absorber Quote
It's possible, but even using a spreader is often borderline, especially if there's no third hand available to hold things in place.
My next investment is a spreader that is clamped in place using a split collet.
Translated on 27-10-2026, 18:12.
Post29-09-2019, 10:18    Subject: Audi A3 8P Wheel Bearing Housing & Shock Absorber Quote
Looking for experiences with wheel bearing housings from original Audi versus Vaico or other suppliers...
Are the positions of the attachment points absolutely identical compared to the original part?
 Radlagergehäuse Audi A3 8P
 File size:  1.68 MB
 Viewed:  375 times
 Radaufhängung Audi A3 8P
 File size:  2.31 MB
 Viewed:  421 times
Translated on 27-10-2026, 18:13.
vag-driver
Post02-10-2019, 6:07    Subject: Audi A3 8P Wheel Bearing Housing & Shock Absorber Quote
dieselschrauber wrote:
Are the positions of the attachment points / mounting points absolutely identical compared to the original part?
That's how it should be. Fortunately, I've never had any problems with premium providers in the aftermarket.
Andreas
Post02-10-2019, 16:56    Subject: Audi A3 8P Wheel Bearing Housing & Shock Absorber Quote
vag-driver wrote:
Are the positions of the attachment points/mounting points absolutely identical compared to the original part?
That should be the case. Fortunately, I have never had any problems with premium providers in the aftermarket.
Very well, because the price difference is a factor of 4, and furthermore, I don't want to buy spare parts from a place where they were too reluctant to do a repair.
Translated on 27-10-2026, 18:14.
Post04-10-2019, 9:00    Subject: Audi A3 8P Wheel Bearing Housing & Shock Absorber Quote
"Premium" is Lemförder, and then there's a long gap until anything else comes close.
Translated on 27-10-2026, 18:15.
Post05-10-2019, 13:25    Subject: Audi A3 8P Wheel Bearing Housing & Shock Absorber Quote
Premium is Lemförder, and then there's a long gap.........
Unfortunately, that's the case. TRW is also being discontinued and is partially original equipment.
You just don't know about the other providers.
As I mentioned before... I prefer to buy the original product when in doubt. It gives me peace of mind.
Mpire
Avatar-Mpire
2019 Skoda Octavia
dieselschrauber and kiter likes this.
Post08-10-2019, 14:32    Subject: Audi A3 8P Wheel Bearing Housing & Shock Absorber Quote
Hello.
I've been using almost exclusively TRW parts for the past while (about 1.5 years).
Axle parts, rubber bushings, control arms, tie rods, brake calipers, rotors/pads, and brake cables. The quality, workmanship, and fit were always identical to the original equipment (OE) part. With axle parts, the deviation after measurement was actually hardly measurable, or there was no need to correct it.
Mpire
Translated on 27-10-2026, 18:16.
kiter likes this.
Post09-10-2019, 21:23    Subject: Audi A3 8P Wheel Bearing Housing & Shock Absorber Quote
Hello.
Assembly without calibration, the steering wheel is misaligned by 1-1.5 finger widths on the country road. icon_biggrin.gif The steering gear is okay, but ABS/ESP errors disappear after driving a few hundred meters. }
Okay, I need to get the car aligned first, and then I'll see. Tomorrow, I'll try driving on a really straight road. It can't be that bad; the steering wheel on my A6 was even more off, completely crooked.
Thank you to all who provided suggestions!
Translated on 27-10-2026, 18:17.
Post13-10-2019, 17:51    Subject: Audi A3 8P Wheel Bearing Housing & Shock Absorber Quote
Thank you again to all the helpers, everything is okay now. icon_biggrin.gif
The steering was adjusted using a very simple string method, which worked perfectly.
Translated on 27-10-2026, 18:18.
No new posts Brake fluid change Audi A4 8K Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi Engine Codes: Types, MKB, GKB, AKB, MJ Technical Data
No new posts Audi APS Coding: How To & Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A4 8K Wheel Bearing Housing Transmission, Chassis, Body & Interior
No new posts Shock absorber is making a cracking noise Transmission, Chassis, Body & Interior
No new posts Expected lifespan of T6 shock absorbers Transmission, Chassis, Body & Interior
No new posts Shock Absorber Boot: Do You Really Need One? Transmission, Chassis, Body & Interior
